Recommendations on TRD pro lift kits
Discussion in '5th Gen 4Runners (2010-2024)' started by @Jerry, Feb 18, 2023.
  1. Feb 18, 2023 at 4:33 PM
    @Jerry
    @Jerry [OP] New Member
    ONZ
    2020 4Runner TRD PRO
    OK, well, let's start with a lift kit. What lift kit would you recommend? For a trd pro
    This is where I sit with 285/70/17 with a Westcott lift
    wanting to run a Km3 285/75/17
  2. Feb 18, 2023 at 4:40 PM
    08TXRunner
    08TXRunner New Member
    '20 SR5P
  3. Feb 18, 2023 at 9:29 PM
    EC15
    EC15 ...
  4. Feb 19, 2023 at 5:46 AM
    Ironguy New Member
    It looks pretty well lifted at the moment.
    hossler1788 likes this.
  5. Feb 22, 2023 at 10:56 AM
    Juan2022
    Juan2022 New Member
    Juan
    RGV
    2022 4 Runner TRD Pro
    None
    The KM3 won’t fit with WD kit?
  6. Mar 6, 2023 at 6:55 PM
    matoolie
    Michael
    2021 Lunar Pro
    I doubt 285/75/17 will fit with any lift unless you do a body mount chop, especially if you get aftermarket UCA’s to get proper caster. They will probably fit with your Wescott kit and body mount chop. Give them a call.
  7. Mar 6, 2023 at 6:59 PM
    GrantA
    North Carolina
    Fully locked 2020 SR5 Premium
  8. Mar 6, 2023 at 7:36 PM
    Juan2022
    Juan2022 New Member
    Juan
    RGV
    None
    Will a KM3 285/70/17 fit with WD kit?
  9. Mar 6, 2023 at 7:47 PM
    matoolie
    Michael
    2021 Lunar Pro
    Yes they should. Will have to remove front mud flaps. If you add aftermarket UCA’s, which will be required to get correct caster even though Wescott says you don’t need them, it will be close to body mounts. I am running 285/70/17 falken wildpeaks with Wescott kit and OME UCA’s and I clear the body mounts with about 3/8” clearance. I even checked clearance at full steering lock and full compression of suspension. Body mount clearance with factory UCA’s will be more, but you will not be able to get correct caster with Wescott lift. Camber and toe will be ok, but not caster.
    Dir4219 likes this.
  10. Mar 7, 2023 at 3:31 AM
    Juan2022
    Juan2022 New Member
    Juan
    RGV
    None
    285/70/17 falken wildpeaks, are they mud terrains?
  11. Mar 7, 2023 at 4:05 AM
    matoolie
    Michael
    2021 Lunar Pro
    No
  12. Mar 7, 2023 at 10:48 AM
    Matt97
    Matt97 New Member
    Matt
    Hawaii
    2021 Lunar Rock 4Runner TRD Pro
    Lighting: - Morimoto XB LED Headlights (Gen 2) - Morimoto XB LED Taillights - Baja Designs SAE Amber Fog lights - Baja Designs S8 30” light bar (Front bumper) Interior - Victory 4x4 Rear Window Storage MOLLE Panels - Victory 4x4 Interior Cargo Basket - KTJO Carbon Fiber Steering Wheel (Red) - Pedal Commander Armor - CBI Covert Baja Front Bumper w/bull bar - TRD Pro Skid Plate - Westcott Designs 0 degree Rock Sliders (With Step plates) Wheels/Tires - Cooper STT Pros 285/70/17 - RRW RR6-H Matte Bronze wheels
    I have a 21 TRD Pro with westcott designs lift. Just installed 285/70/17 Cooper STT Pros with a -10 offset wheel. Front bumper needed minor trimming (can’t even tell). Front mud flaps had to be removed as the tire rubs a little on the body mount. Going back to shop soon for alignment to move the tire forward
  13. Mar 7, 2023 at 11:10 AM
    Juan2022
    Juan2022 New Member
    Juan
    RGV
    None
    So I would need uca’s to run 285/70/17 MT’s on the WD kit on my 4 runner trd pro?
  14. Mar 7, 2023 at 11:13 AM
    Mr. Snuffleupagus
    Brandt
    2022 TRD Pro
    Yes I very much think so and even then you will likely rub when off roading. To run the 285 MTs I would consider both UCAs and a BMC with the WD lift to be sure you can still Offroad the vehicle without a ton of rubbing.
  15. Mar 7, 2023 at 11:15 AM
    matoolie
    Michael
    2021 Lunar Pro
    The -10 offset is contributing to the slight rub so hopefully alignment will help move tire forward. Quick note from my personal experience with the Wescott lift and aftermarket UCA's: the factory 7", +4mm offset TRD PRO wheels and 8" -0mm offset aftermarket wheels will clear body mount with 285/70/17 tires.
    Matt97[QUOTED] likes this.
  16. Mar 7, 2023 at 11:18 AM
    matoolie
    Michael
    2021 Lunar Pro
    Not required. But after alignment, likely you will not have caster numbers in the green after getting camber and toe in the green. Probably close though. Aftermarket UCA's will get caster in the green.
  17. Mar 7, 2023 at 11:20 AM
    Matt97
    Matt97 New Member
    Matt
    Hawaii
    Thanks for the input! I’m hoping the alignment helps because Im trying to avoid doing a BMC. But if it doesn’t work I’ll prob just end up doing the BMC.
    matoolie[QUOTED] likes this.
  18. Mar 7, 2023 at 11:29 AM
    Juan2022
    Juan2022 New Member
    Juan
    RGV
    None
    I plan on keeping the pro wheels.
