Recommendations for 2.5"-3" lift kit?
Discussion in '5th Gen 4Runners (2010-2024)' started by 907sr5, Sep 9, 2024.
  1. Sep 9, 2024 at 11:32 AM
    907sr5
    907sr5 [OP] New Member
    2016 4Runner SR5
    17x9 wheels 285/70 tires
    Trying to stay in a budget. Any recommendations for a lift kit within $2k?
  2. Sep 9, 2024 at 11:37 AM
    Thacrow
    Thacrow New Member
    2021 ORP
    Speed holes
    Portals
    Hilux1 likes this.
  3. Sep 9, 2024 at 11:41 AM
    Eibach
    Hilux1 likes this.
  4. Sep 9, 2024 at 11:59 AM
    Thacrow
    Thacrow New Member
    2021 ORP
    Speed holes
    are you ever going to add any other weight? like bumper? winch etc etc etc. if so you will need heavier duty coils. Or you'll sag.
    Bilstein - 5100 Fronts and Rears $468.00
    https://www.headstrongoffroad.com/store/p3603/Bilstein_-_5100_Fronts_and_Rears_[Lexus_GX460_2010-2023,_Toyota_4Runner_2010-2023,_Toyota_FJ_Cruiser_2010-2014]_-_24-328258_33-313146.html
    Front springs - about $250
    https://www.headstrongoffroad.com/store/c171/Front_Shocks_-_Coils_-_Coilovers_-_4Runner_2010_.html
    Rear Springs - about $250
    https://www.headstrongoffroad.com/s...s_-_Airbags_-_Rear_Coils_-_4Runner_2010_.html
    Over 2 inches you'll need an upper control arm. Maybe OME? $500
    Plus alignment. You doing the install?
    You really cant go wrong with anything unless you add a bunch of weight later on standard load springs.
    Or call Accutune and tell them your budget and see if they have something that works for you
    Toy4X4 and nova like this.
  5. Sep 9, 2024 at 12:00 PM
    If its 2wd you can use a +2.5" spacer kit up front and leave the back alone and it will have about 3/4" of rake and look great
    If its a 4wd its higher in the front from the factory so for +2.5" up front you can use a spacer on top of the OEM shock
    doing +2.5 up front is going to leave the rear about -.5 low so its going to look a little nose high. You are most likely going to want to add a +1" spacer or +1" rear spring in the rear to have a little rake.
    The eibach +1" rear spring is a little stiffer than stock, you might like it you might not but it gives right at +7/8" from what i have seen after installs.
    If you stop at +2.5" up front you dont have to replace the upper A-arms you can still get the caster pretty well spot on. If you go higher than 2.5 up front you cant get the caster back in spec and really need the new upper A-arms to get the alignment right.
  6. Sep 9, 2024 at 7:43 PM
    ADV4RNR
    ADV4RNR New Member
    Bob
    2019 Off-Road Premium
    typical lift, tires, skid plates and rock sliders
    I put Dobinsons on my 19 Off Road Premium. I went the original twin tube shocks. Zero regrets!
    It's been almost a year and I really like the performance both off road and on. Spent a week at Sand Hollow in Utah running the dunes and rocks, and another week in Moab. Exceeded my expectations.
    I've also spent a ton of time running the two tracks here in Upper Michigan.
    Put on the appropriate springs for the weight you'll be carrying. They have a bunch of different options.
    I would go with them again without hesitation.
  7. Sep 9, 2024 at 9:16 PM
    Acesandeights
    Acesandeights #34
    2024 ORP
    Bilstein 5100, mic drop
  8. Sep 9, 2024 at 9:32 PM
    1SilverRunner
    1SilverRunner My boy, blue
    Tejas
    22 TRD Off Road Premium
    Front Bumper: C4 Fabrication Low-Profile Bumper Warn Evo10-S Winch w/ Warn wireless adapter Extreme LED dual color light bar w/ Cali raised LED OEM style switch Bumper Cover Trimmed For Clearance Rear Bumper: 80% Off Road Rear Bash Bar Armor: RCI Skid plate package C4 Gas tank skid RCI Rear diff skid RCI Shock Skids RSG Angled/ Plated Sliders Total Chaos Cam Tab Gussets Total Chaos Spindle Gussets 41.22 Hitch Slider Suspension: Dobinsons IMS long travel shocks: (Front: IMS59-50574 w/ C59-352 Springs) (Rear: IMS59-50575 w/ C59-675v Springs) Apex Chassis Tie Rod Assemblies (KIT410) Apache Off Road UCAs Apache Off Road HD Rear Links (Upper and Lower) Apache Off Road Rear Sway Bar Links Dobinsons Track Bar Front Sway Bar Delete DuroBumps Rear Bump stops PerryParts Front Bump stops DRKDSS Track Bar Correction kit Dobinsons Diff Drop Wheels/ Tires: RRW 17x8.5 -12 RR6-H Wheels 285/75/17 Falken A/T4W 1.25" SpiderTrax Spacers BMC, Pinch Weld Folded. C4 High Clearance Fender Liners Performance: OTT Tuned Scan Gauge II for Temp Monitoring Yota Shop Diff Breather Storage Solutions: LFD Cross-Bars Aiden James Customs Gear Plate w/ Slide Out Tables *Backordered. Rado Designs Molle storage panels and top shelf Glove Box organizer Center Console organizer Interior: Diode Dynamics LED Interior lighting (Warm white ftw) Meso Customs Hatch lights Meso Customs Door Handle Covers Ram ball mount for Garmin In-Touch Mini II FitCamX Dash Camera Scosche phone mount Weathertech floor matts Misc: Nano Ceramic Tint (Including windshield and sunroof) Midland MXT575 and Ghost Antenna Cali Raised LED 27W Ditch Lights OVS Nomadic 6.5' Awning AVS Low Profile Vent Visor AVS Bugflector II Diode Dynamic puddle lights LasFit Reverse lights LED license plate lights Ark Splash Guards Ark Mud Flap Deletes AJT Push-To-Start Button +Midland handheld GMRS radios, Baofeng UV-5R Ham radio, recovery gear, water purification system, lifeboat food rations, trauma kit, fire extinguisher and fire starting kit stay on board.
    +1 for Dobinson
    Edit: Specifically the Dobinson IMS setup. They offer long travel front shocks that should retain some good downtravel even at 2.5-3" of lift height.
    Without long travel front shocks I'd advise to stay under 2" of lift height in the front.
    Beware that their rear long travel shocks are great off road but require longer brake lines and possibly offset upper links. Long travel front shocks and normal rear shocks are a great option to stay in your budget. Here's a link that you might find helpful.
    https://exitoffroad.com/product/dobinsons-1-to-3-5-build-a-kit-toyota-4runner-5th-gen/
  9. Sep 10, 2024 at 6:43 AM
    Nick B
    Nick B New Member
    SW Florida
    2010 TE, 2024 ORP
    I’ve never heard of Head Strong Off-road . Is this a good company to deal with ?
  10. Sep 10, 2024 at 6:45 AM
    Squatting Pigeon
    Holden
    North Texas
    Reach out to @memario1214 (hotshot Offroad). He can get some options together for you. Dude’s customer service is unmatched :thumbsup:
    memario1214 and snoope like this.
  11. Sep 10, 2024 at 3:04 PM
    memario1214
    memario1214 Hotshot Offroad Staff Member Vendor
    Colton
    Missoula, MT
    Under $2k you have a handful of options as long as you don't plan on getting too crazy. Just know that at the 2.5"+ level the costs starts to creep up as more supporting mods begin to be required. Can you share a little bit about if you have any additional weight on the truck, and how you use it day to day?
    Squatting Pigeon likes this.
