Rear window won’t open
Discussion in '2nd Gen 4Runners (1990-1995)' started by dwb133, Oct 31, 2023.
  1. Oct 31, 2023 at 2:57 AM
    dwb133
    dwb133 [OP] New Member
    My rear window just stopped working. Key turns, it went up yesterday and that was it. Any ideas?
    Thanks
  2. Oct 31, 2023 at 3:47 AM
    Did you check the fuse?
  3. Oct 31, 2023 at 9:30 AM
    trlhiker
    trlhiker Lazy Bum
    1992 4Runner SR5 V6 4X4
    Pull the back panel off and test the motor. If motor is good and fuses are good and it will not work with either the key or switch in center console, then it is probably the relay. Also are you sure back door is locked and all lock switches are off?
  4. Oct 31, 2023 at 9:42 AM
    Daddykool
    Make sure the wiper is fully home. Maybe even lift up on it a little. Window won’t move if wiper isn’t home, and wiper won’t move if window isn’t fully up.
  5. Oct 31, 2023 at 12:39 PM
    dwb133
    Thks. Trying everything now
