rear windo switch
Discussion in '5th Gen 4Runners (2010-2024)' started by Tama1968, Jan 29, 2020.
  1. Jan 29, 2020 at 4:57 PM
    Tama1968
    Tama1968 [OP] New Member
    Florida
    T4R SR5 in Classic Silver
    so I just noticed tonight...my rear window operates with the key switch on the rear hatch, but the console switch doesn't work. wonder if she's broke or is there some weird condition that's keeping it from working? wiper appears to be full up and the rear hatch is closed properly.
  2. Jan 29, 2020 at 5:04 PM
    Rodents???
  3. Jan 29, 2020 at 5:58 PM
    MeefZah
    MeefZah ------------
    Lexington, Ohio
    2020 GX4(Runner)60
    Confirm ignition on?
  4. Jan 29, 2020 at 6:40 PM
    Tama1968
    Florida
    ignition is on. never had rodent issues before, but anything is possible
  5. Jan 29, 2020 at 6:51 PM
    NightOwl
    NightOwl 1985 Toyota 4 Runner DLX 22REC
    Amos
    Ballwin, MO
    LCE header, 2.5 inch exhaust, 31x 10.50 BF Goodrich, 15 X 8 aluminum wheels, Bilstein Shocks, 3 inch lift kit, 3M fender flares
    You know these 4 Runners have such a weird thing with the rear window...mine is a 1985 and every summer I take the top off and put it on in the fall...so this year...not unusual...the console works Great...but the rear hatch key lets the window go down but I can't roll it up...but it rolls up with the console switch??? I've read where the driver side bolts holding the removable top have to be installed the same because a longer bolt holds down a safety switch...also the harness that you disconnect when removing the top is sensitive...it's kind of like having a broom stick with skulls and shaking them...every year I take on and off and one year it all works and the next it doesn't...probably not much help...Sorry!!!
  6. Jan 30, 2020 at 5:16 AM
    Tama1968
    Florida
    SOLVED. It was a DAIS error.
    The Dumb A** In Seat had the window lock switch on. Thanks for the tips guys. I forgot the #1 rule...check the easy stuff first.
    mrmike7189, SlvrSlug and MyWyfsRnnr like this.
