Rear suspension recommendations
Discussion in '5th Gen 4Runners (2010-2024)' started by sushi520vx, May 30, 2024.
  1. May 30, 2024 at 8:43 AM
    sushi520vx
    sushi520vx [OP] New Member
    2017 4Runner SR5 premium
    Bilstein 6112 leveling kit front. Bilstein 5112 rear
    I need some advice as to my rear suspension. 2017 4runner, bilstein 6112 leveling kit up front and 5112 rear shocks w/stock springs.
    When Im towing my boat, the rear sag's down a bit and also since installing the 6112's and new springs up front, the front is nice and firm....no body roll up front but....I can feel a bit of roll in the rear. Its not bad but it's noticeable if your paying attention.
    As far as the vehicles usage, 70% around town, 15% hiway, 5% towing, 10% off road (beach and dirt roads. No rock crawling, no heavy off roading.
    Any suggestions would be greatly appreciated!
  2. May 30, 2024 at 9:03 AM
    Acesandeights
    Acesandeights #34
    2024 ORP
    Do you want it to be stiffer all the time, or do you want it to be level when towing, and only when towing?
    You've stated the current ride/situation, but not the issue(s) you're trying to resolve, what you want out of modifications.
    sushi520vx[OP] likes this.
  3. May 30, 2024 at 9:49 AM
    sushi520vx
    A perfect world....and we know that dont exist. Im looking to keep it level while towing (or closer to level), a but stiffer to minimize the rear body roll (sway), while maintaining the ride something close the ride (not towing) I have now.
  4. May 30, 2024 at 9:56 AM
    Acesandeights
    Acesandeights #34
    2024 ORP
    What about air bags and heavy(er) rear sway bar? You can inflate the bags for towing to keep the sag to a minimum and run them at low pressure all other times?
  5. May 30, 2024 at 10:40 AM
    catbrown357
    catbrown357 New Member
    Tempe
    2011 Limited 4WD
    This is exactly why Toyota engineers made the 4R with front end rake. To be level when towing. You've taken that out, now the ass end "appears" to sag under load. Your best option now is coil spring airbags.
  6. May 30, 2024 at 10:51 AM
    1SilverRunner
    1SilverRunner My boy, blue
    Tejas
    22 TRD Off Road Premium
    Front Bumper: C4 Fabrication Low-Profile Bumper Warn Evo10-S Winch w/ Warn wireless adapter Extreme LED dual color light bar w/ Cali raised LED OEM style switch Bumper Cover Trimmed For Clearance Rear Bumper: 80% Off Road Rear Bash Bar Armor: RCI Skid plate package C4 Gas tank skid RCI Rear diff skid RCI Shock Skids RSG Angled/ Plated Sliders Total Chaos Cam Tab Gussets Total Chaos Spindle Gussets 41.22 Hitch Slider Suspension: Dobinsons IMS long travel shocks: (Front: IMS59-50574 w/ C59-352 Springs) (Rear: IMS59-50575 w/ C59-675v Springs) Apex Chassis Tie Rod Assemblies (KIT410) Apache Off Road UCAs Apache Off Road HD Rear Links (Upper and Lower) Apache Off Road Rear Sway Bar Links Dobinsons Track Bar Front Sway Bar Delete DuroBumps Rear Bump stops PerryParts Front Bump stops DRKDSS Track Bar Correction kit Dobinsons Diff Drop Wheels/ Tires: RRW 17x8.5 -12 RR6-H Wheels 285/75/17 Falken A/T4W 1.25" SpiderTrax Spacers BMC, Pinch Weld Folded. C4 High Clearance Fender Liners Performance: OTT Tuned Scan Gauge II for Temp Monitoring Yota Shop Diff Breather Storage Solutions: LFD Cross-Bars Aiden James Customs Gear Plate w/ Slide Out Tables *Backordered. Rado Designs Molle storage panels and top shelf Glove Box organizer Center Console organizer Interior: Diode Dynamics LED Interior lighting (Warm white ftw) Meso Customs Hatch lights Meso Customs Door Handle Covers Ram ball mount for Garmin In-Touch Mini II FitCamX Dash Camera Scosche phone mount Weathertech floor matts Misc: Nano Ceramic Tint (Including windshield and sunroof) Midland MXT575 and Ghost Antenna Cali Raised LED 27W Ditch Lights OVS Nomadic 6.5' Awning AVS Low Profile Vent Visor AVS Bugflector II Diode Dynamic puddle lights LasFit Reverse lights LED license plate lights Ark Splash Guards Ark Mud Flap Deletes AJT Push-To-Start Button +Midland handheld GMRS radios, Baofeng UV-5R Ham radio, recovery gear, water purification system, lifeboat food rations, trauma kit, fire extinguisher and fire starting kit stay on board.
    ^ This.
    Rake is not a bad thing imo.
    If you like your stance and ride quality where it is I'd recommend airbags for towing specifically.
    Or you could get stiffer springs and live with some usable rake. The Dobinsons C59-323 come to mind for your application. They are about the stock height but a 220lb rate (stock I believe is 150lb)
    https://exitoffroad.com/product/dobinsons-1-to-3-5-build-a-kit-toyota-4runner-5th-gen/
    https://exitoffroad.com/product/dob...l-springs-for-lexus-gx460-and-toyota-4runner/
  7. May 30, 2024 at 11:36 AM
    backpacker
    backpacker New Member
    2023 TRD ORP
    Also for loading up the cargo area. It doesn't have the same impact pound-for-pound as tongue weight, but it still matters.
  8. May 30, 2024 at 11:54 AM
    sushi520vx
    Air bags are definitely a strong possibility but I also seen some posts about sumo springs. Anyone have any thoughts or experience with those?
  9. May 30, 2024 at 11:56 AM
    sushi520vx
    Those 220lb springs may solve the problem as well
  10. May 30, 2024 at 1:04 PM
    Acesandeights
    Acesandeights #34
    2024 ORP
    Except the heavier springs will impact the ride 100% of the time. You won't have the same ride you do now.
  11. May 30, 2024 at 1:32 PM
    hossler1788
    hossler1788 Turtle
    Joshua
    Central Pa
    2020 4runner
    Eibach rear springs may be what your looking for 1" of lift and a 205lb spring rate. Dobinson also what's "stock height" springs but with a 220 lb spring rate.
    Oem spring rate is 160-180lbs
  12. Jul 12, 2024 at 12:04 PM
    sushi520vx
    A quick follow up on this. I ended up installing air bags. Installation was easy, I think it took longer to get the floor jack out along with jack stands and tools. I cut the old rubber bump stops with a band saw which took about 10 sec each. Ive been playing around with the pressure to find the sweet spots. Looks like 16 psi unloaded, 18 with some cargo, and 24psi towing the boat.
