Rear Seal Fix
Discussion in '3rd Gen 4Runners (1996-2002)' started by OBX Shred Mobile, May 23, 2024.
  1. May 23, 2024 at 8:56 AM
    OBX Shred Mobile
    OBX Shred Mobile [OP] New Member
    1999 Limited V6 Auto 4WD
    How much should I expect to pay to have my rear seal oil leak fixed and what other services should I consider at the same time. Note - I don't have the time or tools to do this myself. Thanks.
  2. May 23, 2024 at 10:52 AM
    that'smy4runner
    that'smy4runner New Member
    If its a manual transmission you should have the clutch replaced.
    roboturner likes this.
  3. May 23, 2024 at 11:36 AM
    Whole transmission has to come out. This includes the 4x4 transfer case.
    Like was mentioned, get the clutch done if you have a manual.
    Now is the time for resealing the oil pan too I think unless it shows absolutely no signs of leaks.
    Same with the oil cooler on the side of the block.
    At least $1.5k. More likely $2k.
  4. May 23, 2024 at 11:51 AM
    that'smy4runner
    If you can find someone to do it. The shops in my small town all declined to do my clutch job.
  5. May 24, 2024 at 5:56 AM
    that'smy4runner
    It doesn't really take much in the way of special tools to do the job, but it does take time if (like me) you aren't a particulrly skilled mechanic. A tranny jack ($100 at Harbor Freight) and less than $100 worth of other tools (stubby ratchets, wobble extensions, seal puller) maybe a bearing puller will do it. Not a fun job but a big money saver
