Rear quarter panel window decals... bubbles
Discussion in '5th Gen 4Runners (2010-2024)' started by RotaDGF, Jan 31, 2025 at 9:04 AM.
  1. Jan 31, 2025 at 9:04 AM
    RotaDGF
    RotaDGF [OP] New Member
    Marty
    2019 TRD Off Road
    Put rear quarter panel window (both sides) decals on.
    Was fairly easy to do.
    But,,, have far too many small pea size or smaller bubbles showing.
    Any ideas to remove? Used the plastic card to remove some of them.
    Any ideas?
    Friend told me to leave them alone and they over time may shrink and go away.
    When I put clear over lay on my Apple Watch had small bubbles. They went away.
  2. Jan 31, 2025 at 9:06 AM
    Photon_Chaser 49787 and counting…
    Sierra Nevada Mountains and the Central Coast
    Small pin, prick the bubbles at their lowest point of contact with the glass and smooth out towards the pin hole.
    Toy4X4, Daddykool and TrailSpecial22 like this.
  3. Jan 31, 2025 at 10:42 AM
    ID_Yeti
    ID_Yeti New Member
    2024 ORP
    I would hit them with a heat gun first and try to push them out with a CC, go from bubble to the edge both with heat and CC. If that doesn't work or starts to distort the decal then I would move to the hole method with the smallest sewing needle I could find.
  4. Jan 31, 2025 at 2:39 PM
    JimmyAGR
    JimmyAGR New Member
    Jimmy
    Jacksonville
    2020 ORP
    Leave it in the sun, the heat will dry up the moisture.
  5. Feb 1, 2025 at 2:02 PM
    TRoosevelt
    TRoosevelt New Member
    Ty
    2022 Lunar Rock 4Runner
    1.5 Inch Lift 33’s
    Yeah it may take a few weeks for the bubbles to go away. Also, less quality film tends to bubble more.
  6. Feb 1, 2025 at 5:53 PM
    Daddykool
    If you’re in a cool climate, might be best to wait it out.
