Rear PWR window help!
Discussion in '3rd Gen 4Runners (1996-2002)' started by Ace115, Apr 24, 2020.
  1. Apr 24, 2020 at 12:13 PM
    Ace115
    Ace115 [OP] New Member
    Andrew
    2000 T4R 4x SR5
    Hey all you that are in the know. About a week ago I used the rear pwr window and it worked but really slowly. Then over this last weekend the window quit going all the way down. It’ll move like 2” and then stop, I can put it back up so it isn’t frozen for sure. Has something worn out? Where should I start with this repair?
  2. Apr 24, 2020 at 12:30 PM
    Open it up and see if anything obvious is bent or stuck.
    Maybe a good cleaning would help also.
    Ace115[OP] likes this.
  3. Apr 25, 2020 at 1:27 AM
    Clutchplate
    Clutchplate New Member
    96 4runner 3.4 Liter
    I had the same problem a while back. It turned out to be one of the window track bolts pulled out of mounting hole, i had to install longer bolt. You will need to remove inside tailgate panel to access all parts.
