Rear panels of back seat
Discussion in '5th Gen 4Runners (2010-2024)' started by frostytrd, Aug 20, 2023.
  1. Aug 20, 2023 at 7:12 PM
    frostytrd
    frostytrd [OP] New Member
    I’m pretty sure I cracked the back panel on the back of my rear seats when sitting on them. Are there any problems that may come up in the future.
  2. Aug 20, 2023 at 7:20 PM
    Oakboro, N.C
    Welcome to the forum!
    Do you have any pictures of the damaged area? What year 4Runer do you currently have?
  3. Aug 20, 2023 at 7:22 PM
    frostytrd
    I have a 23 and i do not have pictured but when feeling the other left seat compared to the right seat on the back it definitely feels like one of the panels is cracked. and thanks!
  4. Aug 20, 2023 at 7:37 PM
    I tool my panel off a while back because I was thinking of making a thicker panel that could take some weight…which which is why I have the pic below.
    The panel is plastic and it’s mounted onto some steel strap that is welded to the frame. Hopefully it didn’t crack a weld on one of the straps.
    When you take the plastic panel off, make sure to use a trim pry tool at the point where the green clips are.
  5. Aug 20, 2023 at 7:40 PM
    frostytrd
    are there any replacements for these that are more durable?
  6. Aug 20, 2023 at 8:11 PM
    Oakboro, N.C
    I have not seen any aftermarket ones available as of of the current date.
  7. Aug 20, 2023 at 8:22 PM
    frostytrd
    contemplating on replacing it, not sure if it’s worth it though
  8. Aug 20, 2023 at 8:38 PM
    In my case, I was seeing if I could make one out of 1/4 plywood or similar…so it could serve as part of the load floor. But in the end decided not to do that. Since I don’t like the idea of the seat back structure as a whole being a load surface. Might make a whole removable superstructure over the seats that will take flooring, and bolt in at the seat bottom bolt points. It’s not this year’s project though.
  9. Aug 20, 2023 at 11:25 PM
    pastoreater
    pastoreater New Member
    2023 sr5 2wd toyo 115T
    Gonna jump in and ask for tips on loading large heavy items in the interior. I pushed the seats forward, I figure the load resting closer to the base of the seat frame is better. Did you break yours?
    I loaded the F out of a matrix for a long time and have already had piles of boxes and the set of stock tires in this thing. The stock tire rolls perfectly out the back with ~2mm clearance to the headliner I love it.
  10. Aug 21, 2023 at 12:57 AM
    LuLu
    LuLu New Member
    Utopia
    2022 TRD Sport
    Why not just get a plywood (primed and paint) to lay across whilst loading heavy items.
    Itself of ripping apart the interiors. My 2c
