Rear outlet power
Discussion in '5th Gen 4Runners (2010-2024)' started by Elvis4R, Oct 30, 2022.
  1. Oct 30, 2022 at 5:10 AM
    Elvis4R
    Elvis4R [OP] New Member
    New Hampshire
    2022 Nautical Blue 4Runner SR5 Premium.
    Garmin traffic camera, Goodyear Dura Trac stock size.
    Hello,
    I've never had a vehicle that had the outlet in back and was curious if anyone had used it for short periods of time using a shop vac? With vehicle running of course. Or is the vac too much for it?
    Thanks in advance.
    Dave
  2. Oct 30, 2022 at 5:38 AM
    doc4216
    doc4216 New Member
    Shannon
    The Land of Cle
    2015 SR5 Premium
    Dasaíta HU, Bilstein 5100s, AT Tires, Coveted grill lights
    Mine works just fine with a shop vac.
  3. Oct 30, 2022 at 7:57 AM
    Henry J
    Sacramento Ca
    Nvm
  4. Oct 30, 2022 at 8:08 AM
    Isn't the outlet rated at 400 watts? Or, did they make it more on newer ones?
    Just did a quick search, and an average size shop vac (Rigid) was rated at 9 amps, which is 1080 watts at 120V.
    I wouldn't recommend it, unless you have a very small shop vac that's rated at 3.33 amps or less. It might work fine for awhile, but it could burn out the inverter.
    I'd run an extension cord, or get a battery powered shop vac from whatever brand of power tools you prefer.
    KilluFirst and 2Toys like this.
  5. Oct 30, 2022 at 12:56 PM
    doc4216
    doc4216 New Member
    Shannon
    The Land of Cle
    2015 SR5 Premium
    I should have added, my shop vac is smaller size.
  6. Oct 30, 2022 at 1:11 PM
    I tried using my Shark house vacuum with mine. It "worked", but seemed to b running at reduced speed and wasn't really effective.
  7. Oct 30, 2022 at 1:12 PM
    Curlystooge
    Curlystooge Member
    2022 limited in magnetic grey
    What do others use the outlet for? Blowing up air mattresses, margarita blender?
  8. Oct 30, 2022 at 1:13 PM
    I have used mine for air mattresses. I can't recall using it for anything besides that.
  9. Oct 30, 2022 at 1:37 PM
    Yes. Also, charging the jackery while out on trails during camping trips. You could used the regular 12v charger too. I think the 120v plug is faster than the 12v for the jackery.
    semprenissart and Thatbassguy like this.
  10. Oct 30, 2022 at 2:14 PM
    doc4216
    doc4216 New Member
    Shannon
    The Land of Cle
    2015 SR5 Premium
    Bicycle pump
  11. Oct 30, 2022 at 2:27 PM
    Air mattress, yes. And, I'm suddenly tempted to see if anyone makes a blender that won't overload it. :D
    I used to use an inverter to power my bass amp for camping trip jam sessions back in my younger days.
    Rock-N-Roll likes this.
  12. Oct 30, 2022 at 3:33 PM
    Beat you to it!
    The only drawback I see is that it doesn’t include a blender Molle mount. :p
    Smoothies and jam sessions! They need to bring back the party mode button :D:D:D
  13. Oct 30, 2022 at 4:00 PM
    :bananadance:
    So, what you're saying is that we're doing Margaritas and daiquiris at the next Wisconsin crew camping trip?
    I don't know how to make either from scratch... yet. Sounds like I have some rough homework ahead of me.
  14. Oct 30, 2022 at 5:04 PM
    Well, I certainly wouldn’t want to impose…
    but yes, that’s what Im saying. :p:D
  15. Oct 31, 2022 at 10:51 AM
    Overland WT
    Overland WT Grumpy Old Guy
    Bryan
    West Texas
    2017 TRD Off Road
    Many with many more to go
    Yes, yes they do. We have one... but it s 2-stroke and its bitchin! We've bought them for gifts for friends who have "everything".
    https://blenderexpert.com/the-gas-powered-blender/
    As for the inverter, it has an automatic shut off if the amp draw is too high.
  16. Oct 31, 2022 at 1:20 PM
    I definitely don't need a gas powered blender, as fun as it looks. I was looking for something that draws less than 400 watts, so I could just use the onboard power.
    I guess if people are able to run a shop vac off of the inverter, it must have higher output than they are rated for. I assumed it would be fused to protect itself. I just wouldn't expect it to run something that draws that much.
  17. Oct 31, 2022 at 4:40 PM
    Maybe if they made a 2-stroke powered blender with a 12v starter that draws less than 400 watts. I sense untapped market potential :D
  18. Oct 31, 2022 at 5:28 PM
    I like where you're going with this!
