Rear left and right door lock actuator doesn't work
Discussion in '5th Gen 4Runners (2010-2024)' started by langlaisjc, Jan 11, 2023.
  1. Jan 11, 2023 at 5:47 AM
    langlaisjc
    langlaisjc [OP] New Member
    Hi,
    I was wondering if anybody here had the same issue. I woke up this morning and tried to unlock all door with the keyfob and I also tried the unlock button in the car and the rear doors won't unlock. I unlock them manualy with no problem, but they won't lock back when I press the button. Front doors work just fine, but rear doors there is nothing hapening. I have look over the internet and can't even find what is the fuse and/or relay for those power lock.
    4runner 2015 limited edition
    Anybody have an idea ?
  2. Jan 11, 2023 at 6:24 AM
    Year? Model? More information needed.
    Child door lock safety engaged?
    08TXRunner likes this.
  3. Jan 11, 2023 at 6:30 AM
    langlaisjc
    Sorry I forgot !
    I have a 4runner 2015 limited edition.
  4. Jan 11, 2023 at 6:35 AM
    Polymers
    Polymers New Member
    2014 Limited 4WD
    Had to replace two actuators last year on my 2014. Seems like a common occurence. Several YouTube how to's out there. I bought new instead of trying the repair.
  5. Jan 11, 2023 at 7:07 AM
    langlaisjc
    Both doors failed at the same time ? seems unlikely no ? I tought maybe there was a fuse for those rear doors but I can't find anything over the net.
    Jean-Christophe Langlais
  6. Jan 11, 2023 at 8:00 AM
    Piney
    Piney New Member
    2021 Cement trail edition
    None
    https://youtu.be/K_AGepBE9Is
    I had the same problem along with window actuators…perhaps your battery drained down prior ?
    Easy fix If so….
  7. Jan 11, 2023 at 8:07 AM
    langlaisjc
    Both rear doors window work fine, only the lock-unlock doesn't work. I don't think it's the battery because the car started in -20C this morning :p
  8. Jan 11, 2023 at 8:21 AM
    Piney
    Piney New Member
    None
    Lol…no battery problem for sure ! Mine completely drained & the procedure linked above solved the issue. Still good info for future reference.
    Maybe a similar process for just door actuators ? Let us know your findings…
  9. Jan 11, 2023 at 8:53 AM
    langlaisjc
    glwood54 : I did not see your question but yeah the child lock feature but I tried both on or off and it does not solve my problem. I'm just surprise that both lock system could have failed a the same time.
    glwood54 likes this.
  10. Jan 11, 2023 at 9:04 AM
    steelevo
    Utah
    I'd imagine that if there was a fuse it would be for the entire power lock system and not independent doors or zones. Dead actuators are a possibility.
  11. Jan 11, 2023 at 9:07 AM
    langlaisjc
    Could it be a possibility that actuators can be frozen since its freezing cold outside?
    Piney likes this.
  12. Jan 12, 2023 at 4:32 AM
    langlaisjc
    Quick update:
    At the end of my shift everything was working fine... I am still not sure what happened but i am sure happy it's gone.
