Rear hatch won’t open unless engine is turned on.
Discussion in '4th Gen 4Runners (2003-2009)' started by Haroldvonanusiii, Jun 5, 2024.
  1. Jun 5, 2024 at 6:16 PM
    Haroldvonanusiii
    Haroldvonanusiii [OP] New Member
    Harold
    2004 4runner V8 4x4
    I have a 2004 4wd v8 4runner, and there’s something screwy going in the rear hatch. I’ve seen posts here about rear hatch problems, but not this one in particular.
    1. The rear hatch won’t open unless the engine is running
    2. Rear window will roll up and down but you have to hold the button down the whole time (except when I’ve been driving for awhile, it will be good and auto-roll up and down)
    3. Rear wiper and defroster won’t work (again, unless I’ve been driving for a while)
    4. Using the rear lock doesn’t roll window up or down as it should.
    In regards to the first problem, I’ve recently replaced the brain in the rear hatch and now the hatch will open if a.) the engine is running or b.) the engine is off but the ignition key is at “start”, which is an improvement.
    Im baffled by all this weirdness. I gotta think that’s there is one fix that will restore regular function to the rear defrost, wiper and rear window.
    could it be a relay?
  2. Jun 6, 2024 at 6:21 AM
    Bluesky 07
    Bluesky 07 Not a New Member
    Russell
    Northern Georgia
    Silver ‘07 Sport V6 4WD @ 263K miles
    “Deep” Satoshi grille | X-REAS delete / TRD Offroad front springs & Bilstein 4600 shocks + FJC rear springs | Weathertech front & rear mats | Tinted front windows | Floor Armor cargo mat | TPMS bypass | LED interior, tag, & reverse lights | BlueSea Systems console USB power ports | Gentex 453 autodim mirror w/Homelink & compass | Kenwood DDX373BT HU + Audiovox backup camera | Fumoto F-103S | Bazooka tube subwoofer | Kenwood speakers & KAC-M1804 amp | Philips H9/9011 headlight bulbs | Rexing V1 Gen3 dash cam | Map light mod | Breather mod | Off-road Nav Setup | Power Stop Z36 brakes | OBD Fusion diagnostics
    Check the battery, even if you’re certain it’s okay. These are typical bad battery symptoms. Alternator too (actually Toyota calls it a generator). Sometimes the battery is good but not getting enough power to charge properly.
  3. Jun 6, 2024 at 10:24 AM
    Haroldvonanusiii
    Harold
    2004 4runner V8 4x4
    I just replaced the battery. No luck
  4. Jun 6, 2024 at 10:47 AM
    Bluesky 07
    Russell
    Northern Georgia
    Still might check the alternator. The charging system on 4th Gens can be a rabbit hole. My issues went away when I swapped out the alternator.
