Rear Hatch struts (shocks) upgrade
Discussion in '5th Gen 4Runners (2010-2024)' started by 57buick, Apr 25, 2018.
  1. Apr 25, 2018 at 4:35 PM
    57buick
    57buick [OP] New Member
    David
    2018 4runner Off Road premium
    33" Duratracs, TRD Wheels, Addicted Off-Road front Bumper
    So in preperation for some upgrades coming soon like a ladder and stuff, I went ahead and upgraded the shocks on the rear hatch.
    Gobi is over charging people $100 for these. The nerve right? lol
    Well I did some research and found these at liftsupportsdepot.com and they were $42 shipped instead of $145 at Gobi plus shipping. They were SKU 6156
    Strong Arm 6156 Gas Charged Liftgate Lift Support
    https://www.liftsupportsdepot.com/s...rolet-gmc-liftgate-lift-support-strut-49124w/
    Next, measuring the down force to test them out and see how much stronger they are.
    kolter45, Captain Spalding and 2A4R like this.
  2. Apr 25, 2018 at 4:37 PM
    57buick
    David
    So here are pictures of my tests with my fishing scale attached to the pull handle. You can see that the stock ones took 16 pounds of pull before the door started coming down. Then with the new ones installed it took 24 pounds of pull before the hatch started coming down.
    And I can't tell a difference actually pulling it closed by hand but it appears it's a 50% increase in hold open force.
  3. Apr 25, 2018 at 8:04 PM
    rkwfxd
    rkwfxd New Member
    Rich
    Whittier - So Cal
    Nice find. In another thread somewhere a guy found some shorter struts so that his hatch did not hit the top of his garage. Nice idea but I'm too cheap. I just use a length of paracord and a D-ring between the right rear tight down ring and the pull handle on the hatch. That way I can limit it when I need to but allow it to fully open when I don't.
  4. Apr 25, 2018 at 9:07 PM
    57buick
    David
    My vehicle doesnt go in the garage so I want it to open fully for easy access to everything
  5. May 3, 2020 at 8:59 AM
    Charlievee
    Charlievee New Member
    How are these holding up?... Pun not intended, but it works.
    kolter45 likes this.
  6. May 3, 2020 at 9:03 AM
    57buick
    David
    They held up fine but in the end I traded the 4runner in for another dodge ram diesel. SO I am no longer in the 4runner world.
    Charlievee[QUOTED] likes this.
  7. May 3, 2020 at 9:07 AM
    Charlievee
    How long did you have them?
  8. May 3, 2020 at 9:26 AM
    I replaced the hatch struts in my 3rd gen with the Strong Arms and was very happy with them, that was about 4 yrs. ago.
    Captain Spalding and Charlievee like this.
  9. May 3, 2020 at 9:49 AM
    mcat707
    mcat707 MURDERED TRD
    NOR*CAL - Solano County
    2015 TRDPro - Attitude Black Metallic 218
    Any leads on where to get shorter lift supports? My rear cargo hatch also touches the top of my garage.
  10. May 3, 2020 at 10:10 AM
    Charlievee
    found this
  11. Jul 12, 2021 at 3:55 PM
    littlemrnofear
    littlemrnofear New Member
    k
    Cavalry TRD Pro
    just confirming the model 6156 worked? the website only mentions that this fits a Yukon, Escalade or Suburban... just want to make sure before I order them. TY!!
  12. Jul 15, 2021 at 2:17 PM
    MAXIM
    MAXIM New Member
    After replacing speakers with OEM+ setup (adds about 8 lbs for big magnets) and installing full sheets of sound insulation in tailgate I got Liftsupportdepot.com HD struts to open additional weight. So far they work great and plenty powerful, the only thing I wish these had slow down future at the end of opening to keep thing from stress stops.
  13. Nov 25, 2021 at 11:33 PM
    808Yoda
    808Yoda New Member
    2014 Trail
    Did you end up ordering the 6156? If so, we’re the right fit? I need to order some after installing a Westscott Designs ladder.
  14. Apr 22, 2022 at 6:35 AM
    SR5ives
    SR5ives New Member
    Ross
    2015 White SR5
    Gobi roof rack and ladder
    If you use the Search by Make function you can find the appropriate strut. SKU: 6550-W is what I will be ordering.
  15. Oct 11, 2022 at 7:46 AM
    BiggestAUfan
    BiggestAUfan New Member
    2018 Super White TRD Off Road Premium XP
    Pending ;)
    @808Yoda I have the Wescott Designs ladder also. LOVE it but that thing is heavy. Which sku did you order 6156 or 6550-W?
    Many thanks!
    808Yoda likes this.
  16. Oct 11, 2022 at 8:05 AM
    SR5ives
    SR5ives New Member
    Ross
    2015 White SR5
    I'd go with the 6156. The Gobi ladder is pretty light, and my 6550-W struts dont spring the lift gate open - even when it's warm out. I don't have to help it open, but it's not fast. The 6156 struts have 28 more pounds of force.
  17. Oct 11, 2022 at 8:56 AM
    808Yoda
    808Yoda New Member
    2014 Trail
    I did some searching a while back and used part#PM4004-W. It is heavier duty and has been working great so far with no issues. Make sure to support the hatch when replacing struts and remove the TOP connectors first. If you remove the bottom, it’s under tension and can break your taillight when disconnected.
    https://www.liftsupportsdepot.com/22-56-lift-supports-depot-pm4004-lift-support-pm4004-w/
