Rear end sag?
Discussion in '2nd Gen 4Runners (1990-1995)' started by monsterman2375, Oct 2, 2018.
  1. Oct 2, 2018 at 12:44 PM
    monsterman2375
    monsterman2375 [OP] New Member
    Michael
    1995 flat black 4Runner
    none
    I have a '95 and it looks almost as if the rear suspension is sagging a little bit, but it might just be the torsion bars. In all honesty, I have no idea if it's supposed to be an inch or two lower than the front but hey, it doesn't hurt to ask.
  2. Oct 2, 2018 at 1:31 PM
    If it is oem then i would say at a minimum you need new springs, i would do shocks also. And no it is not supposed to be lower in the rear.
  3. Oct 2, 2018 at 2:07 PM
    Kyle11863
    Kyle11863 King of the BS
    Big Bear California
    1990 Toyota 4Runner SR5 V6 5 Speed Manual
    Doug Thorley long tube headers and lots of mud
    It is possible that someone previously twisted the torsion bars to get a little more lift out of them but the rear on these are known to sag over time. Its a common, easy to fix problem.
  4. Mar 7, 2019 at 9:36 AM
    cramos8
    cramos8 New Member
    Colton
    Red 4runner 4x4
    Mine had sag when i bought it. I put 2 inch coil spacers in the back and it leveled it out perfect.
  5. Mar 7, 2019 at 11:27 AM
    HoBoDanny
    HoBoDanny Dude...
    Daniel
    Kentucky
    2004 SR5 V6 4WD 4Runner
    Shouldn’t be lower. Most likely time to replace rear suspension.
  6. May 20, 2019 at 3:28 PM
    atgparker
    atgparker Cal Poly, ETME 1988
    Andrew
    Mission Viejo, CA
    1991 White 4Runner 3.0 L
    I put Dayco 1-1/4" poly urethane spacers on top of the OEM springs along with some SkyJacker M95 mono-tube shocks. This has leveled out the front to back distance from the fender to the ground to be 36 inches at the front and 35-1/2 to 35-3/4 at the rear depending on fuel tank level. New 31x10.5-R15 Cooper Discoveries are the tires. Before the spacer the rear was at 34 and change and did look as though things were sagged. I have not changed the rear brake biasing arm and so far stopping seems the same although with the lift the pressure to the rear brakes should be decreased with all else being the same!
    Fourtoad likes this.
