Rear Differential Oil Capacity
Discussion in '5th Gen 4Runners (2010-2024)' started by tvhj, Aug 27, 2021.
  1. Aug 27, 2021 at 12:05 PM
    tvhj
    tvhj [OP] New Member
    Memphis, Tn.
    2014 2wd SR5
    2014 4R SR5 2wd, 80,000mi. I just put a set of new stock size tires on which are much quieter than what I pulled off. Now at 65 to 75mph I can here a slight whine that sounds like rear gear, very slight. Did some searches here and a couple other places and am still not sure if I got it right. Changed the rear diff. oil with it warm and only got 2 1/2 quarts out on level ground. It took all of the 3 new quarts to get to just under the bottom of the fill plug threads. Does this sound right? Thanks for any info.
  2. Aug 27, 2021 at 2:01 PM
    thirdyota
    Brian
    Cincinnati, OH
    2017 T4R TRD Off Road Premium
    Sounds like your diff was a bit underfilled before. Here is a link to some useful info for you in regards to drive line servicing....
    https://trail4runner.com/2018/12/24/4runner-driveline-fluids-how-and-when-to-change-them/
    Edit: just noticed that yours is a 2wd. I'd check the owners manual if you have it to confirm rear diff oil capacity. I'm assuming it's the same as a 4wd, but not positive.
    2nd edit: just consulted my manual, no separate listing for a 2wd...
    Toy4X4 likes this.
  3. Aug 28, 2021 at 9:13 AM
    tvhj
    Memphis, Tn.
    2014 2wd SR5
    Thanks Thirdyota for the info.
