Rear differential air breather, 5th gen 4Runner Limited.
Discussion in '5th Gen 4Runners (2010-2024)' started by LuisASol, Apr 2, 2020.
  1. Apr 2, 2020 at 12:03 PM
    LuisASol
    LuisASol [OP] New Member
    Hello,
    I am showing how it looks after I install the rear differential air breather. I will show more modifications to the 4runner Limited as I go, because there is not good information about Limited edition modifications.
    Thank you.
    The hose is attached to the air breather with the provided fitting. The hose is installed and protected with an old garden hose. I left enough hose for it to adjust to the movement of the axle. I jacked up the vehicle all the way up until the tire was up in the air to ensure there was enough hose.
    Here I protect the hose (top of the picture). with an old garden hose from rubbing into a metal part.
    The hose continues towards the engine compartment and attaches to other rubber parts to protect it from wearing off and also placed far from heating areas.
    After I attached the hose to multiple areas above the transmission the hose reached the engine bay by the fire wall.
    The hose is attached to multiple places on the passenger side of the engine bay towards the fire wall to reach the final destination, air filter and support fitting.
    Before any final adjustment I checked every part to ensure good fitting and enough hose to adjust to the movement of the vehicle. Also, making sure the hood will not touch the air filter.
    https://www.youtube.com/watch?v=Co841XeOflg
  2. Apr 3, 2020 at 7:56 AM
    peter2772000
    peter2772000 New Member
    Peter
    Montreal/Cape Coral
    2019 TRD Pro
    Nice thread, thx for posting it
  3. Apr 3, 2020 at 8:12 AM
    Jynarik
    Jynarik I like boobies
    Austin Texas
    2019 trd pro voodoo
    Good deal. Thanks for the post - this is my next project
