Rear diff breather for cheap
Discussion in '5th Gen 4Runners (2010-2024)' started by java, Jun 6, 2024.
  1. Jun 6, 2024 at 7:08 PM
    java
    java [OP] fauxrunner
    2023 ORP ice cap
    Took a couple hours after work today to install the rear diff breather extension. Just some cheap 5/16 fuel line ,the nipple part(will post part #) from Toyota, and some clampa from Home Depot.
    Saker likes this.
  2. Jun 6, 2024 at 7:13 PM
    java
    2023 ORP ice cap
    I chose to route inside the jack compartment, there is a grommet hidden somewhere on the towards bottom, if you look for it you'll definitely find it. Popped the grommet and fed a healthy length of line through the hole, the got under the vehicle to locate it. It came out somewhere withing the bumper, pryed the bumper a bit and pulled the line through. Then routed over the crossmember to the nipple and secured with a clamp. Made sure to leave plenty slack for suspension travel. Secured with zip tie to prevent the line from getting close to the exhaust. Hopefully.
    Saker likes this.
  3. Jun 6, 2024 at 7:16 PM
    java
    2023 ORP ice cap
    Lol, I spent the longest time on drilling the gommet, and putting it back with the fuel line through it, was very awkward. In hindsight, I would drill the grommet, put it back in the hole and then feed the hose through, would have made life much easier.
    Saker likes this.
  4. Jun 6, 2024 at 7:16 PM
    java
    2023 ORP ice cap
    Finished product.
    Saker likes this.
  5. Jun 6, 2024 at 7:17 PM
    java
    2023 ORP ice cap
    While in there I sprayed some Fluid Film on and in the crossmembers, and the spare tire chain and mechanism.
  6. Jun 6, 2024 at 7:19 PM
    java
    2023 ORP ice cap
    Left the e locker breather alone this come, will come back later to splice it to the main line.
    Saker likes this.
  7. Jun 6, 2024 at 9:35 PM
    Good job, but please cut the zip tie ends off flush, you’ll thank me later.
    Saker likes this.
  8. Jun 6, 2024 at 11:03 PM
    coryanderson
    coryanderson New Member
    Cory
    2018 SR5 4x4 - black and tan
    Flush cuts for the win! I think I have 5 floating around in my garage and vehicles now.
