Rear diff and pinion specs
Discussion in '2nd Gen 4Runners (1990-1995)' started by SR5 turbo, Aug 23, 2020.
  1. Aug 23, 2020 at 1:33 PM
    SR5 turbo
    SR5 turbo [OP] New Member
    1995 white 4runner
    I am replacing all the bearings in the rear end and was hoping someone had the factory specs for the backlash, pre load and any other specified torque Numbers
    I drive a 1995 4 runner with the 3.0 and it has four wheel drive if that helps
  2. Aug 23, 2020 at 5:50 PM
    bthp223
    bthp223 New Member
    Nevada
    1990 4X4
    We have a few guys very knowledgeable that will be along I’m sure to help you out. Welcome to the club.
  3. Aug 23, 2020 at 6:46 PM
    SR5 turbo
    1995 white 4runner
    Thank you seems like there’s a lot of helpful and kind people here .
  4. Aug 24, 2020 at 1:30 PM
    Justthemechanic
    Justthemechanic New Member
    Nevada desert
    94 4Runner SR5, 5 speed, 3.0
    OME 2” lift, BudBuilt armor, RRO sliders, Spartan rear locker
    Go to Suspension and Axle, Rear Differential-Differential Carrier, in the FSM you will find all of the information to rebuild the rear carrier.
  5. Aug 24, 2020 at 4:27 PM
    SR5 turbo
    1995 white 4runner
    Thank you very much
  6. Aug 28, 2020 at 3:09 PM
    atgparker
    atgparker Cal Poly, ETME 1988
    Andrew
    Mission Viejo, CA
    1991 White 4Runner 3.0 L
    You will need a magnetic base stand with a dial indicator to be able to accurately read and set the gear backlash. I highly recommend recording the as-is backlash before you take it apart. If you pull the pinion shaft this will get a whole lot more complicated!... A press and bearing crush will most likely be required to remove and set the new bearings. In addition a shim kit may be needed if the new bearings fail to position the pinion in the same place as before the replacement was initiated. This is not likely but the bearing spacer on the pinion shaft can be a problem with new bearings and without shims the preload can be hard to obtain. Marlin Crawler for axle seals and pinion shaft seals, the only way to go!
  7. Aug 28, 2020 at 3:51 PM
    SR5 turbo
    1995 white 4runner
    Thank you for the additional information a couple things that I hadn’t considered
