Rear Dif breather
Discussion in '5th Gen 4Runners (2010-2024)' started by morfdq, Feb 6, 2024.
  1. Feb 6, 2024 at 9:07 AM
    morfdq [OP] New Member
    Hello,
    I recently did some off-roading that included passing through 2–3 feet of water. After doing it I remembered that water could get into the rear dif through the breather and I swapped the fluid. My question is about the breather “tube”. Do I need to do any maintenance on that and if so, where exactly is it located? Thank you
  2. Feb 6, 2024 at 9:26 AM
    Another option is to extend the breather to a higher location. ARB makes a kit to locate the breather in the engine bay. I opted for a DIY to the area behind the driver's side tail light from a writeup I found online.
  3. Feb 6, 2024 at 9:49 AM
    Ctreg
    Ctreg New Member
    ARB kit is very good and easy to install. I have one and I'm in Florida and go in a lot of moderately deep muddy water. I haven't had any trouble with water going into my differential since the install.
  4. Feb 6, 2024 at 10:25 AM
    Florida is exactly where I did it.
  5. Feb 6, 2024 at 10:29 AM
    The vent it right on top of the pumpkin.
  6. Feb 6, 2024 at 12:39 PM
    totmacher
    totmacher New Member
    Daniel
    West TN
    2018 SR5 Nautical Blue
    done some stuff to it
    Did you see any sign of water in the diff oil when you drained it?
    I tend to wonder if extending the vent is really a "need" versus being one of those "unlikely but it's cheap so do it just in case".
  7. Feb 6, 2024 at 12:46 PM
    Ctreg
    Ctreg New Member
    I saw a pale, milky appearance (indicating water intrusion) of my diff oil when i changed it before I installed the breather line.
    3JOH22A and totmacher like this.
  8. Feb 6, 2024 at 3:41 PM
    Saker New Member
    21 Black T4RORP
    BS67 likes this.
  9. Feb 6, 2024 at 8:55 PM
    nova
    nova New Member
    mike
    Prescott Valley - Arizona
    slightly modified LE
    The issue I’ve had was the temperature drops from the water and shuts the factory breather. Negative pressure sucks water through the axle seal and now there’s water in the diff. With the ARB or such, it doesn’t close up the breather and the pressure is equalized.
    Saker likes this.
  10. Feb 7, 2024 at 12:27 AM
    Gripster
    Gripster New Member
    2016 Trail Premium
    Does anyone know why the elocker has a breather which is separate from the diff breather? Internally are those two regions separate from each other? I did the DIY breather mode by combining the two vents and running a line near the fuel filler cap but now I am paranoid about the oil fumes in the elocker chamber.
