Rear defroster does not work all the way
Discussion in '4th Gen 4Runners (2003-2009)' started by Endoz87, Jan 24, 2024.
  1. Jan 24, 2024 at 10:21 PM
    Endoz87
    Endoz87 [OP] New Member
    4th gen 4runner
    I went to use my rear defroster and i noticed that it was not working on the top four lines of the glass. There is a small spot on the top four lines in a row that looks like it is trying to work but not going all the way across. Any ideas on how to fix this?
  2. Feb 1, 2024 at 1:38 PM
    Bluesky 07
    Bluesky 07 Not a New Member
    Russell
    Northern Georgia
    Silver ‘07 Sport V6 4WD @ 263K miles
    “Deep” Satoshi grille | X-REAS delete / TRD Offroad front springs & Bilstein 4600 shocks + FJC rear springs | Weathertech front & rear mats | Tinted front windows | Floor Armor cargo mat | TPMS bypass | LED interior, tag, & reverse lights | BlueSea Systems console USB power ports | Gentex 453 autodim mirror w/Homelink & compass | Kenwood DDX373BT HU + Audiovox backup camera | Fumoto F-103S | Bazooka tube subwoofer | Kenwood speakers & KAC-M1804 amp | Philips H9/9011 headlight bulbs | Rexing V1 Gen3 dash cam | Map light mod | Breather mod | Off-road Nav Setup | Power Stop Z36 brakes | OBD Fusion diagnostics
    Don’t turn the rear defroster on again until you research rear windows shattering without warning. This is a known 4th Gen issue where something goes wrong with the connections causing some of the lines to heat up while others don’t. Depending on the ambient temperature, this can result in unexpected shattering of the glass.
    I didn’t find anything here but check on the other forum and there’s also a about it.
    xtremewlr likes this.
  3. Feb 1, 2024 at 6:29 PM
    Endoz87
    4th gen 4runner
    Well thanks for the heads up. It does not look like it is a simple fix so i will just end up not using it any more.
    Bluesky 07 likes this.
  4. Feb 1, 2024 at 8:30 PM
    Bluesky 07
    Russell
    Northern Georgia
    Toyota actually extended the warranty coverage through 2018 but IIRC, it was only if your glass actually broke, not like a preventative thing to keep it from happening. I think that’s total BS but what can you do? The bummer is that the rear defroster switch also turns on the heated mirrors so when I need the mirrors defrosted, I turn it on just long enough to get them clear and then immediately off.
