Rear dash cam
Discussion in '5th Gen 4Runners (2010-2024)' started by remoguy55, Apr 19, 2022.
  1. Apr 19, 2022 at 8:28 AM
    remoguy55
    remoguy55 [OP] New Member
    2020 SR5 Premium 4WD
    Hey everyone. Anyone care to share their recommendations or setups they have for a rear dash cam? I already have a front and I don't plan on having the two connected. Interested if anyone has a rear dash separate without running any wires through the headliner.
  2. Apr 19, 2022 at 9:13 AM
    My biggest problem is fixing the rear camera it self. I see no videos how to remove that headliner pin / plug. Everyone says its easy but scared to play with anything holding the headliner. Also I see it has to be a custom bracket you need to buy a piece of aluminum from hardware store, drill it, and put a nut.
  3. Apr 19, 2022 at 10:55 AM
    Bikeric
    Bikeric New Member
    Eric
    2003 V8 4x4 ARB Locked and Lifted on 35's with 4.88's
    My rear door didn't come with a dash. I'm not installing a new rear dash either.
    :rimshot:
  4. Apr 19, 2022 at 10:56 AM
    LoL..:D:D:D
    Bikeric[QUOTED] likes this.
  5. Apr 19, 2022 at 11:30 AM
    I ran my wiring under the passenger door sill panel following the OEM harness to the rear. I went up to the headliner at the D pillar. I did this to avoid having to go through the entire headliner plus I have a moonroof so another obstacle to deal with.
    I guess you could have two systems by using the 12 volt outlet in the rear but then you have to sync both to each other.
    Dabigono and remoguy55[OP] like this.
  6. Apr 19, 2022 at 11:41 AM
    remoguy55
    I wonder if I just suction one to the rear side window with an arm swingout and use the 12V in the cargo area. hopefully the wideview camera would catch everything
