Rear cargo net
Discussion in '5th Gen 4Runners (2010-2024)' started by rracraa, Jan 27, 2023.
  1. Jan 27, 2023 at 7:36 AM
    rracraa
    rracraa [OP] New Member
    2008 and 2018 SR5 T4R
    Hi, does anyone here use the rear net in their hatch area? PT34789100 is the part number I have and it fits extremely tight between the top hook and the bottom D ring, almost seems like its going to break. I triple checked the PN fits my 2018 2 row.
  2. Jan 27, 2023 at 7:53 AM
    Henry J
    Sacramento Ca
    I do when I go to Costco. It keeps my melons from rolling all over the place
    rracraa[OP] likes this.
  3. Jan 27, 2023 at 8:06 AM
    rracraa
    yeah I don't want my melons rolling all over anymore. Were those top and bottom connections extremely tight or is it supposed to have some slack
  4. Jan 27, 2023 at 8:21 AM
    Henry J
    Sacramento Ca
    It has some give. I actually normally keep it up but I take it off when traveling out of town. Not a fan my my bourbon bouncing around either.
  5. Jan 28, 2023 at 5:06 AM
    Beachguy
    2024 TRP ORP
    I have one and use it every time I pick up groceries or really anything that I don’t want rolling around. I leave both top and bottom on the right side connected and just fold it back to the right out of the way when I don’t need it. I find that adequate for getting it out of the way. When I do need it I pull it across and only connect the top, rarely the bottom. Works perfectly and the weight of whatever I put in it keeps the left top from coming off. When I’m done with it I just pull it off the left top and push it all back to the right out of the way.
    if I do feel it necessary to connect both points on the left I do the bottom first since the top just slips around the contact point.
  6. Jan 28, 2023 at 1:02 PM
    UncleShorty
    UncleShorty New Member
    Have had and used one for years. Wouldn't give it up.
    Very handy at the grocery or big box to keep your stuff from knockin' around. I ran a bungee cord from one D ring to the other, thru the net. That helps hold the bottom in place when the net is loaded.
    Best thing about it? I don't have to chase the tomato soup down the driveway when it falls out as I open the end gate...
    rickystl likes this.
  7. Jan 31, 2023 at 10:18 AM
    universalfrost
    universalfrost New Member
    Joseph
    Belpre, Ohio
    Predator bars, blackout emblems, TRD Pro Wheels, Falken AT3W tires
    I have the one from Toyota for my 2022 with 3rd row.. very handy ... especially when stuff is shifting while driving and doesn't self unload when i open the back hatch... mine is not too tight on top or bottom attachment points and has some give for larger items
  8. Jan 31, 2023 at 1:58 PM
    rracraa
    I ended up buying another one and sent the first one back, same part number and it fits perfectly now so it must have been some mix up or just made wrong
  9. May 19, 2023 at 11:18 AM
    Rocko9999
    Rocko9999 New Member
    2011 Limited
    Anyone know of a good flat net for the cargo area? I don't like the vertical nets.
  10. May 19, 2023 at 8:09 PM
    NOS4A2-1
    NOS4A2-1 New Member
    NY
    2020 Venture
    I ordered a cargo spider net from BAM awhile back. Worked well when I needed it, less than $30.00 (PT347-89101)
  11. May 22, 2023 at 8:11 AM
    Rocko9999
    2011 Limited
    Not a fan of the vertical nets. The horizontal nets make putting boxes or larger items under it easy and keeps them from sliding.
  12. May 22, 2023 at 9:18 AM
    NOS4A2-1
    NOS4A2-1 New Member
    NY
    2020 Venture
    Yes, I understood. This is exactly what you’re looking for. Look up the part number I gave you. Don’t be deceived by the first picture that shows it being used vertically.
    Home TOYOTA PT347-89101
  13. May 22, 2023 at 12:00 PM
    Rocko9999
    2011 Limited
    Ah nice. Thanks.
    NOS4A2-1[QUOTED] likes this.
  14. May 22, 2023 at 11:13 PM
    donnermel
    donnermel New Member
    dita.yota
    Truckee/Tahoe
    ‘16 Trail Premium Super White w/ KDSS
    Dobinsons lift and UCA, RCI sliders and front engine skid, H9 bulb swap, Sprint Booster, KnN air filter, Canvasback covers, Raingler cargo net, AVS Window Shade deflectors, Heritage Grill with raptor lights Summer Wheels: Ryder RR03 matte gunmetal with Falken Wildpeaks 285/75/17 Winter Wheels: 18” KD Wheels with Blizzaks Rack is OEM - but changed to black with LFD crossbars Diode Dynamics Ss3 fogs
    Check out Raingler cargo nets - super simple, quick release, flat net. It’s awesome for grocery getting and keeping everything in one place 4wheeling on bumpy roads.
  15. May 23, 2023 at 12:29 PM
    fast eddie
    fast eddie New Member
    Eddie
    Pompano Beach, FL & Durango, CO
    2023 dark grey runner limited all time 4wd
    None
    But.......what does the flat net do for your melons?
