Rear Camera Relocate Question
Discussion in '5th Gen 4Runners (2010-2024)' started by Oldtoyotaguy, Apr 5, 2020.
  1. Apr 5, 2020 at 6:22 AM
    Oldtoyotaguy
    Oldtoyotaguy [OP] Paid cash for it
    2018 Toyota 4 Runner Offroad
    Hi, I’m considering a rear swing out on the new rear bumper I’m about to order, and it will require a rear backup camera relocate. I’ve watched a few videos on it, and it seems pretty straightforward, basically opening up the hatch liner, soldering some wires, and rerouting them to a location of choice. My question is for anyone on here that has done this: did you do anything special to waterproof the wires where they enter the camera? The reason I ask this is because the pro videos from C4, Victory, etc. which are all excellent btw, basically show just moving the camera and wrapping some electrical tape and plastic conduit around it. Since the camera was designed to live in a dry environment inside the rear hatch, I’m just wondering if anyone has any experience with how well it and it’s tiny wiring survive in the hostile outside world of rain, dirt, salt, slush and snow? Thanks!
  2. Apr 5, 2020 at 6:37 AM
    Dark Knight
    Dark Knight Get off my lawn
  3. Apr 5, 2020 at 6:42 AM
    Oldtoyotaguy
    Thanks, Dark Knight, but my question wasn’t so much about concern for the soldered connections, which can be made waterproof fairly easily, but where the small gauge wires enter the housing of the camera. No one seems to do anything to protect this area, and I am wondering if it’s strong enough to withstand the outside world. Sure, you can try to fill it up with rtv, but sometimes water still leaks around sealers like that when there’s wires running through it.
    Just wondering what others have done. Maybe it’s no problem. But whenever I modify something i try to anticipate the unforeseen consequences, haha.
  4. Apr 5, 2020 at 6:52 AM
    Oldtoyotaguy
    Btw, those connectors you referenced are excellent.
  5. Apr 5, 2020 at 7:28 AM
    WanderlostOverland
    WanderlostOverland New Member
    We used a good quality silicon to seal up our camera. It's been two years now with no issues.
    Oldtoyotaguy[OP] likes this.
  6. Apr 5, 2020 at 8:00 AM
    Oldtoyotaguy
    I liked your video as well, WanderlostOverland!
  7. Apr 5, 2020 at 8:23 AM
    WanderlostOverland
    THANKS!
  8. Apr 5, 2020 at 8:24 AM
    peter2772000
    peter2772000 New Member
    Peter
    Montreal/Cape Coral
    2019 TRD Pro
    Not to start an argument, but in my opinion, those connectors are garbage. Cut them apart after bonding them and you'll find minimal solder penetration (wow, that just turned me on....)
    I've tried various methods of heating them up, but the problem is that the necessary heat for good bonding damages the plastic envelope.
    The closest I've come to getting good bonding is by using flux on the exposed wires before heating them up. And it still ain't all that great.
    I purchased a kit like the above through Amazon. Can't throw them out, but personally can't bring myself to use them on anything.
    FYI, there are heat-shrinks out there with a built-in sealant, they're amazing and the only ones I use
  9. Apr 5, 2020 at 8:29 AM
    Oldtoyotaguy
    Yeah, I hear you, peter2772000, no argument from me! I’ve used them successfully, but you need to be patient, and heat them slowly not to damage the plastic heat shrink. That being said, I definitely believe in using whatever works! I’ve also, hand soldered wires, crimped them etc. If the wires don’t have to survive a hostile outside environment, there’s a greater latitude for how much vigilance you need. Which is why I asked the original question about securing those OEM wires from the elements.
    peter2772000[QUOTED] likes this.
  10. Apr 5, 2020 at 12:19 PM
    Dark Knight
    Never had a problem with solder penetration using them. The key is the heat gun so you can easily control the focus of heat and take your time. Beats a bullet connector any day.
  11. Apr 5, 2020 at 2:10 PM
    peter2772000
    Peter
    Montreal/Cape Coral
    2019 TRD Pro
    Well then, there's something you're doing different. Again, my joints are soldered, just not thoroughly unless the clear plastic jacket gets burnt.
    Have you ever skinned the clear plastic jacket in order to see the actual quality of the joint?
  12. Apr 5, 2020 at 2:18 PM
    Dark Knight
    I usually call it good when the connection doesn’t come apart with a hefty yank. So far, after using about 30 of them, none have come loose.
    The plastic shouldn’t burn before you get a good solder melt. Using the heat gun I get no discoloring of the cloudy/clear plastic.
  13. Apr 5, 2020 at 2:23 PM
    peter2772000
    Peter
    Montreal/Cape Coral
    2019 TRD Pro
    Bud, if only 30% of the wire is soldered, you won't get it to pull apart. And I actually bought a heat gun to use with the connectors.
    In the end, if you're happy with the results, that's what counts. Right?
  14. Apr 6, 2020 at 4:16 PM
    peter2772000
    Peter
    Montreal/Cape Coral
    2019 TRD Pro
    Back to the OP's original post ( and bragging somewhat...), I just ordered the following;
