Rear bench seats making noise going over bumps
Discussion in '5th Gen 4Runners (2010-2024)' started by Sin4R, Jun 25, 2024.
  1. Jun 25, 2024 at 11:26 AM
    Sin4R
    Sin4R [OP] New Member
    2024 Underground Limited
    Mall crawling kit.
    Quick question, does your rear seat makes rattling noise when going over bumpy road? When they are empty, I could see mine vibrate in the rear view mirror, and they start hitting each other around where they split to fold and making rattling noise. Mildly annoying and strange to see so much movement. I had almost the same rear seat setup on Outback and it never made any noises driving over the same bad roads.
  2. Jun 25, 2024 at 11:32 AM
    scanny
    scanny New Member
    Ontario, Canada
    Never heard about it before, maybe seats are not fully seated in the latches which secure them to the floor or those latches got loose somehow.
    Sin4R[OP] likes this.
  3. Jun 25, 2024 at 11:51 AM
    backpacker
    backpacker New Member
    2023 TRD ORP
    Besides this, check on whether they're partially reclined but not fully clicked in. Or someone may have pushed the release to recline them and just left it that way.
    2Toys, Sin4R[OP] and Ripper238 like this.
  4. Jun 25, 2024 at 12:15 PM
    scarkinsmel
    scarkinsmel New Member
    Ed
    2021 ORP
    Yes, mine make a slight rattling noise when up, most noticeably the 60 side of the 60/40 split.
    Both suggestions are good, but I’ve made sure the seats are secure, not reclined, slightly reclined and they are fully secured but the noise, for me, persists. You might have better luck.
    I’ve tried nearly everything I can imagine to stop the noise, to no avail. The back seats are almost never in use so I lay the 60 side flat and no noise.
    If there is someone in the seats in the back it makes no noise. I’m fairly sure it’s something to do with the latch mechanism rattling when it’s latched.
  5. Jun 25, 2024 at 12:20 PM
    Thacrow
    Thacrow New Member
    2021 ORP
    Speed holes
    Mine squeak when my dog or a person is vack there and we go over a bump. Super annoying. Thanks for bringing this up. Going to use some grease when re-assembling since I have it all apart now. See if that helps.
  6. Jun 27, 2024 at 6:59 AM
    Sin4R
    Mall crawling kit.
    Please keep me posted.
    Thacrow[QUOTED] likes this.
