Rear Axle Seal
Discussion in '5th Gen 4Runners (2010-2024)' started by steal, Feb 9, 2023.
  1. Feb 9, 2023 at 8:15 PM
    steal
    steal [OP] New Member
    Washington
    2015 4runner TE
    Anybody have this issue with their 5th gen? Just happened to me. Seeing if anybody has any experience with replacing it. Anything i should look for or get when replacing it since i’ll be replacing it myself. Since i’ll be in there, should i replace the bearings while i’m in there, and would i need my own press for that?
  2. Feb 10, 2023 at 8:03 AM
    tblt44
    tblt44 New Member
    Todd
    Tampa
    2021 4 runner
    N/A
    What seal ?
    At the wheels or the pinion ?
  3. Feb 10, 2023 at 8:54 AM
    steal
    Washington
    2015 4runner TE
    at the wheels.
  4. Feb 10, 2023 at 9:58 AM
    TN_FunRunner
    TN_FunRunner New Member
    Jay
    W. TN
    2018 TRD ORP, 2007 SR5 4WD
    is the breather clogged?
  5. Feb 10, 2023 at 10:02 AM
    steal
    Washington
    2015 4runner TE
    it is not
  6. Feb 10, 2023 at 10:55 AM
    nova
    nova New Member
    mike
    Prescott Valley - Arizona
    slightly modified LE
    How many miles on the clock?
    Check for bearing play to see if it’s necessary.
    post back either way!
    cheers
  7. Feb 10, 2023 at 11:33 AM
    steal
    Washington
    2015 4runner TE
    i got 116k right now. haven’t drove it since i found out which was midway December. I think i’m to the point where i’m just going to buy that 20T harbor freight press and knock it out.
  8. Feb 10, 2023 at 11:40 AM
    nova
    nova New Member
    mike
  9. Feb 10, 2023 at 2:29 PM
    tblt44
    tblt44 New Member
    Todd
    Tampa
    2021 4 runner
    N/A
    Most likely those bearing are good for another 150k plus if it had regular gear oil changes.
  10. Feb 10, 2023 at 3:04 PM
    j cat
    j cat New Member
    massachusetts
    spacer lift front 1inch
    the rear diff of the axle shafts ... then the vent is on the rear diff. the venting is rusted or a frozen lock up ... the forum members are moving the gas cap around it in this area of the diff vent .....
    my 2000 silverado GM the diff vent is around the gasoline cap .....OEM FACTORY spec ..also my 1996 Impala is the OEM off the rear diff , the venting is the factory .
    you have to inspect the venting on the rear diff vent ..
