Re-using TPMS sensor to TRD Pro Wheels - Reprogram Needed?
Discussion in '5th Gen 4Runners (2010-2024)' started by Wootang00, Feb 23, 2021.
  1. Feb 23, 2021 at 8:42 PM
    Wootang00
    Wootang00 [OP] New Member
    Hello,
    I have an new 2021 4Runner SR5 Premium and am going to switch to the TRD Pro Wheel very shortly using the existing stock tires that came with the SUV.
    If I re-use my TPMS from my SR5 Premium wheel and move it to the TRD Pro Wheel, does it need to be reprogrammed?
    The Tire Shop i spoke with sounded like it needed to be re-programmed as it would be moving to another wheel. If it needs to be re-programmed... is this something that the Tire Shop needs to do? Or can be done on our own.
    Please advise. Thanks in advance!
  2. Feb 23, 2021 at 8:45 PM
    edgesalon
    edgesalon New Member
    Te
    18 FunRunner :-)
    i don't think so you only need reprogramming when you get a new TPMS
    a47chuck likes this.
  3. Feb 23, 2021 at 8:51 PM
    Wootang00
    Thank you.. Additionally, Anyone know how much it should cost per tire to move remove existing tire / TPMS sensor from SR5 Premium wheel and mount / balance on TRD Pro wheel? Shops seem to be quoting around $35 per tire... bit pricier than I thought.. I believe the norm is $25.. but $10 to move the TPMS sensor from one wheel to another (without any programming needed) seems a bit excessive?
  4. Feb 24, 2021 at 5:21 AM
    canadian.bacon
    Snowland
    ‘22 Tesla Model Y
    is $40 going to make difference ?
    times are different now, choose a reputable shop and get it done
  5. Feb 24, 2021 at 7:19 AM
    I swapped wheels of my 4runner Limited from stock 20" wheels to 17" TRD Off-road wheels. Discount tire did not change anything extra to swap the TPMS sensors.
  6. Feb 24, 2021 at 8:21 AM
    edgesalon
    Te
    18 FunRunner :-)
    i think for all four i paid $80. including everything at American Tires
