Rattling noise linked to drivetrain
Discussion in '3rd Gen 4Runners (1996-2002)' started by Willem.smith, Nov 16, 2022.
  1. Nov 16, 2022 at 10:51 AM
    Willem.smith
    Willem.smith [OP] New Member
    2001 4runner
    3" lift, shocks, coils, bumper, wheels and tires
    Hey there,
    My 2001 4wd is making a rattling noise that seems to be linked to the drivetrain. It only happens when the truck is in motion and I can neutral the trans, neutral the transfer case, put it in rwd, and even shut the truck off and coast and still hear it. It does seem to be linked to road speed, although it doesn't get way louder or more pronounced at 50mph vs 30, although from 5-20 you can hear it becoming more frequent. This could be because of a faster spinning drivetrain or because vibrations from the road are becoming more frequent, really hard to tell!
    One thing to note that may be related is that I currently have a donut on one of the front wheels. The other day I changed out of 4wd at 35mph and it made a really unhappy low sound (almost like low rumbling tire noise) My first thought is that maybe upon disengaging the 4wd, the center diff locks for a moment (don't know why) and due to my donut, there was a large differential causing the tires to rumble and maybe even damage.
    Would really appreciate any ideas on what this could be, thanks!
  2. Nov 16, 2022 at 1:10 PM
    johndeg1
    johndeg1 New Member
    Johnd
    1999 Sr5
    I had the same issue. It was the “knuckle” attached to the drive train. Apparently needs to be greased every few yrs. It was an easy fix at a trans shop. 90 for the part. 120 in labor.
    I would put the regular tire back on to determine if the donut is related, obviously.
  3. Nov 16, 2022 at 1:47 PM
    Willem.smith
    2001 4runner
    Ok,
    My research has yielded many similar possibilities, that it is a failing joint of some sort, maybe a u-joint.
    I'll try to get a look under it while it's spinning and get the new wheel on when it arrives.
    Thanks for the help!
  4. Nov 16, 2022 at 2:48 PM
    roboturner
    roboturner Dead Eyed
    ‘98 NW 3.4L 5MT SR5 | '18 6MT DCSB Tacoma | '00 IJM 3.4L TRD Tacoma
    grease the zerks on the driveline (just get a gun and some grease off Amazon, $40 and DIY, good to do it every other oil change imo), but also check the swaybar endlinks and panhard - they like to come loose sometimes
  5. Nov 16, 2022 at 2:51 PM
    johndeg1
    johndeg1 New Member
    Johnd
    1999 Sr5
    Yes u-joint/ knuckle, I guess it’s all the same
  6. Nov 16, 2022 at 3:19 PM
    qcTRDct
    qcTRDct New Member
    2022 ORP KDSS
    2 things... the "donut" is for getting you home and parking until you get your proper tire repaired. 4wd on a spare tire of any kind is bad business because the difference in the circumference of the tire will cause binding in the driveline. (This is why you change all 4 tires at once on a 4wd, and the smartest thing to do is have a full sized matching spare and doing a 5 tire rotation at regular intervals).
    Second, and this is because everyone uses different words to describe what they hear, check to make sure that you didn't bend the dust shield in the back of the brake rotor. Again, this would sound more like a scraping than a rattling, but let's rule out something simple.
    PhantomTweak, negusm and roboturner like this.
