rattle/vibration drivers side dash
Discussion in '5th Gen 4Runners (2010-2024)' started by mainerunr, Jul 28, 2024.
  1. Jul 28, 2024 at 4:47 PM
    mainerunr
    mainerunr [OP] New Member
    Maine
    '23 TRD ORP
    Toyo AT3's, Greenlane Sliders
    Started hearing this annoying vibration/rattle sound this week but it was way worse today
    • Happens far less on smooth roads...seems worse in dips, not as bad coming over rises.
    • Only happens between 45 and 65mph (although less between 60 and 65)
    • Sounds almost like a hard wire or something vibrating against the edge of a thin stamped steel part.
    Cannot find anything loose under the dash, the plastic trim at the side of the windshield cowl seems secure...
    I did try moving the thin rubber engine shield and those push pins are loose but it's more of a squeak sound. Could it be that at speed it doesnt squeak?
  2. Jul 28, 2024 at 6:36 PM
    catbrown357
    catbrown357 New Member
    Tempe
    2011 Limited 4WD
    Check the plastic fender liners?
  3. Jul 28, 2024 at 6:49 PM
    4runningMan
    4runningMan New Member
    New Mexico
    To rule it out, just put 3 or 4 little pieces of duck tape along the length of the thin rubber fender liner to keep it from moving around. That fixed my problem entirely. Sometimes it squeaked, sometimes it was a faint rattle. Not anymore.
  4. Jul 29, 2024 at 5:31 AM
    mainerunr
    Maine
    '23 TRD ORP
    Yeah, I wrapped a bread tie under the plastic fastener and no noise this morning, will see if it stays gone...crazy if that's it though...
    jgalt likes this.
  5. Jul 29, 2024 at 7:20 AM
    4runningMan
    New Mexico
    I thought the same thing on mine.
