Rattle in rear wheel well?
Discussion in '5th Gen 4Runners (2010-2024)' started by Sleestaks, Jul 19, 2023.
  1. Jul 19, 2023 at 8:12 AM
    Sleestaks
    Sleestaks [OP] Shape-shifting Reptilian Alien
    2018 OR, Magnetic Gray
    Tires only
    Anyone experience this?
    Another OCD post - I've gotten a crunchy rattle in the passenger side (I think) rear wheel well from time to time, very intermittently. I would write it off as running over something in the road because that's what it sounds like, but it sounds the same every time in the same location. I've checked the suspension as best I can and it looks pretty good.
    Don't know, something loose? Suspension? Brakes? Wheels?
  2. Jul 19, 2023 at 8:15 AM
    is the toolkit loose in the storage cubby?
  3. Jul 19, 2023 at 8:17 AM
    Sleestaks
    Tires only
    Doesn't sound like it's from that side, but you know how sounds travel. Pretty sure it's strapped down, but I'll give it a check -- thanks for the suggestion.
  4. Jul 19, 2023 at 10:21 AM
    Oakboro, N.C
    I had a rear seat not securely latched after folding them down and it created a fairly large rattle in the back area.
    LadeDruck and Sleestaks[OP] like this.
  5. Jul 20, 2023 at 5:54 AM
    BgBmBoo
    BgBmBoo New Member
    Kansas
    That was my first thought too. I've had the jack work loose and rattle. Took me forever to figure it out.
    Sleestaks[OP] likes this.
  6. Jul 26, 2023 at 10:31 PM
    Loco x Toyota
    Loco x Toyota New Member
    Cedar Park, TX
    TRD Pro Solar Octane
    do you use parking brake? I notice rattle noise when parking brake is engaged and I exist the vehicle would trigger that rattle, I'm 200 lbs so that much of weight shifting could upset the parking brake and cause some noise
  7. Jul 27, 2023 at 5:53 AM
    Sleestaks
    Tires only
    Nah, it's while I'm driving -- I've checked all the things (tool kit, etc.) -- haven't had it since I've checked, so we'll see, but pretty sure it wasn't the tools as it's on the passenger side rear and not the driver's
  8. Jul 27, 2023 at 6:47 AM
    LadeDruck
    LadeDruck New Member
    2022 Pearl Effect White Ltd.
    do you have the jbl system?
    the sub and amp package is bolted in with a few bolts right up and into the rear quarter cavity.
    definitely a possible source, it’s weighty and plastic while being hollow.
