Raptor Lights
Discussion in '5th Gen 4Runners (2010-2024)' started by AE1M, Dec 29, 2024.
  1. Dec 29, 2024 at 2:57 PM
    AE1M
    AE1M [OP] New Member
    Bob
    2024 TRD Off-Raod Premium
    Thinking about installing the amber colored Raptor LEDs on 2024 TRP ORP. Why do all the install videos run the wires to the interior fuse box with an add-a-fuse when there is a nice convenient fuse box inside the engine compartment. Much simpler wiring plus less chance of a wire chafing or interfereing with pedals etc…
    Any long term review of these things? Was thinking about an ignition-on fuse or maybe the DRL 10A fuse (with an add-a-fuse). This way I can have them off if I want with the DRL stalk.
    Not interested in an interior fuse install or another panel switch.
    Bob
  2. Dec 29, 2024 at 3:06 PM
    The majority of Raptor light installations have resulted in creating electrical problems on 5th Gens, as reported on this forum. Tread carefully and good luck.
  3. Dec 29, 2024 at 3:06 PM
    Most of the long term reviews are negative. Lights failing after a short amount of time. Weird electrical issues coming up. Fuses randomly blowing.
    Just remember, you own a Toyota, not a Ford.
  4. Dec 29, 2024 at 3:13 PM
    UG244RP
    UG244RP New Member
    andrew
    24 T4Pro
    lots
    I have tried every fuse possibly available for the raptor lights. Inside. Outside. Upside down. Not one has given me success. No start. Had that. Nav screen/radio not work. Yep. Stalled while driving. Yes. In each and every case, rip that crap out and all is good. Makes me mad that I can't get them to work properly for any length of time. I really do like them, don't get me wrong, but damn, why don't they work like they are supposed to??? Would love to know the answer to this question also.,
  5. Dec 29, 2024 at 3:57 PM
    I went to extend where I added a relay harness and a dash switch for my raptor style grill lights only to see they fail after few months. What a waste of time and money for me. Never ever will install raptor style grill lights again.
    BTW I install them on purpose, to be my DRLs, as I used my DRLs as my 2nd set of highbeams / "quad high beams" as some call.
  6. Dec 29, 2024 at 5:05 PM
    Guppy1301
    Guppy1301 New Member
    Silver 2019 TRD ORP
    My marker lights (haha!) have been running for two years with no issues. I bought them from CTH along with my Pro grille. I have them hooked up inside. I also bought an extended fusebox cover from someone here who was selling them. Most likely I will not replace them when they sh!t the bed.
  7. Dec 29, 2024 at 5:51 PM
    AE1M
    Bob
    Wow, if they are simply connected to a fuse in the fuse box under the hood, hoe could they possibly interfere with the nav screen?
  8. Dec 29, 2024 at 6:38 PM
    Imdav2u
    23 TRD PRO
    I ran the wires through a rubber grommet in the firewall, grounded on the bolt for the fuse panel, half tap fuse in an accessory slot. That was last June, so far no issues.
    LCJ77 and Guppy1301 like this.
  9. Dec 29, 2024 at 6:45 PM
    I’d probably use a switched underhood fusebox tap to trigger a relay so they’re powered from the battery.
  10. Dec 29, 2024 at 7:35 PM
    2016Pro
    A terrible idea they look stupid, just as bad as a chrome bull bar
  11. Dec 30, 2024 at 12:57 AM
    Rick G.
    The Texas Hill Country
    2022 SR5 Premium 4WD
    A while back, I installed some so-called Raptor light fixtures in the grill of my 2022 T4R. I didn’t even have them wired up to be operational yet when I inquired here as to why they are called Raptor lights.
    When I was told that FORD had first started calling them that, I thought screw that and removed the Raptor lights from my grill.
    I didn’t want to be looked upon as being a FORD wannabe. lol.
    But, I digress. To each his own. If you like it, cool. I bet most folks who are not FORD owners do not even associate “Raptor” lights with FORD.
  12. Dec 30, 2024 at 1:26 AM
    FourBelugas
    FourBelugas New Member
    23 white ORP
    Spend the money on some quality 9005 LED bulbs for the DRL instead. The raptor lights were only installed on Ford 1/2 tons to imitate(badly) the clearance lights on commercial vehicles and 3/4+ ton pickups and ironically, when I used to drive a 1 ton Ford, I didn't bother checking the box when I ordered the truck, we used to make fun of Raptors for their low payload and lack of a V8 after 2016 or so.
    Putting them on Toyotas would be 2nd hand cringe.
    Old Tanker and catbrown357 like this.
  13. Dec 30, 2024 at 5:06 AM
    Grandpawmoses
    Grandpawmoses Dirty Old Man
    David
    2024 4R TRD Pro
    Too poor to buy anything now
    To answer your question about why some people run the wire to the inside fuse box, they preferred to put them on their own switch so they ran the wiring from the switch to the inside fuse box.
    But I gotta add my feeling about raptor lights, it'd be like saying "I wish this was a Ford".
  14. Dec 30, 2024 at 5:35 AM
    Photon_Chaser 48576 and counting…
    Roger
    Sierra Nevada Mountains
    To put it simply, adding an add-a-fuse to main fuse box inside the engine compartment will result in you not being able to close the lid properly. Maybe there is a low profile add-a-fuse available but I’ve tried twice and said to hell with it. Went with an auxiliary control box wired directly to the battery (post) and never looked back.
    …and thbbttttt to all the haters
    Texas-Gorilla likes this.
  15. Dec 30, 2024 at 5:45 AM
    mainerunr
    mainerunr New Member
    Maine
    '23 TRD ORP
    Toyo AT3's, Greenlane Sliders
    I mean, you're not right. Raptor lights were installed on Raptor F150's because they were required by federal law due to their width, not to imitate anything. Not sure why you made fun of their "low payload", its a half-ton truck with a payload appropriate for a half-ton truck...they also don't ride like their tires are bricks like a 1-ton Ford so...
    STrooper and Nick B like this.
  16. Dec 30, 2024 at 6:09 AM
    Nick B
    Nick B New Member
    SW Florida
    2010 TE, 2024 ORP
    As a former owner of a 6.2L Raptor I totally agree . It’s a 1/2 ton truck with a 1/2 ton payload. Also out of the 25 vehicles I’ve owned the Raptor and my wife’s GX were the two best riding out of the bunch .
    BGH2023 likes this.
  17. Dec 30, 2024 at 6:22 AM
    Texas-Gorilla
    Texas-Gorilla New Member
    2015 Toyota 4Runner SR5
    Can you share what your set up looks like with the auxiliary control box?
  18. Dec 30, 2024 at 6:42 AM
    LCJ77
    LCJ77 New Member
    Gilbertsville,Pa.
    2023 TRD Pro Ice Cap
    No issues on my 2018 I had them on for over 4 years & none so far on my current T4R.
  19. Dec 30, 2024 at 6:58 AM
    Roger
    my build page, post #21
    Texas-Gorilla[QUOTED] likes this.
  20. Dec 30, 2024 at 9:12 AM
    Saker New Member
    21 Black T4RORP
    I’ve not had any issues or weird electrical issues after installing mine. Used add a fuse to the “Tail” slot inside the cab, used an AOB switch (to selectively turn them off if wanted), and a relay.
  21. Dec 30, 2024 at 9:34 AM
    Roger
    Most of the issues happen when folks tie into circuits like IGN or the like when searching for an active when ignition is on circuit. Not necessarily for raptor lights. Seems that such circuits are sensitive to extra loads being placed upon them, causing possible issues like voltage drops or abnormal current draw than what the original circuit was intended for.
    Saker[QUOTED] likes this.
  22. Dec 30, 2024 at 9:57 AM
    Saker New Member
    21 Black T4RORP
    I totally agree.
    This is why some of use have auxiliary circuits that are separate from the OEM electrical circuits!
    That being said, some items that draw milliamperes can be added to non critical circuits without issue.
  23. Dec 30, 2024 at 12:05 PM
    FourBelugas
    23 white ORP
    The raptor lights on F150 Raptors are a subject of wide spread mocking by the heavier duty Ford truck owners. The width-based clearance lights are required for rear view mirrors, cab roof lights, fenders on duallies, etc at the edge of the vehicle, how does putting these lights in the grill help?
    In any case, the F350 I had was wider, taller, and longer than a Raptor and it did not come standard for cab lights or anything, just the external mirrors each had a dim amber light when the lights are on. The grill lights on Raptors are nothing but cosmetic vanity lights.
    But don't mind me, it's not like I have been driving class 3 and up trucks and pickups(yes! there is a difference!) including medium duty chassis cabs for the last 25 years or something.
    2016Pro likes this.
  24. Dec 30, 2024 at 12:06 PM
    1SilverRunner
    1SilverRunner My boy, blue
    Tejas
    22 TRD Off Road Premium
    Front Bumper: C4 Fabrication Low-Profile Bumper Warn Evo10-S Winch w/ Warn wireless adapter Extreme LED dual color light bar w/ Cali raised LED OEM style switch Bumper Cover Trimmed For Clearance Rear Bumper: 80% Off Road Rear Bash Bar (Limited rear bumper version) Armor: RCI Skid plate package C4 Gas tank skid RCI Rear diff skid RCI Shock Skids RSG Angled/ Plated Sliders Total Chaos Cam Tab Gussets Total Chaos Spindle Gussets 41.22 Hitch Slider Suspension: Dobinsons IMS long travel shocks: (Front: IMS59-50574 w/ C59-352 Springs) (Rear: IMS59-50575 w/ C59-675v Springs) Apex Chassis Tie Rod Assemblies (KIT410) Apache Off Road UCAs Apache Off Road HD Rear Links (Upper and Lower) Apache Off Road Rear Sway Bar Links Dobinsons Track Bar Front Sway Bar Deleted DuroBumps Rear Bump stops PerryParts Front Bump stops DRKDSS Track Bar Correction kit Dobinsons Diff Drop Wheels/ Tires: RRW 17x8.5 -12 RR6-H Wheels 285/75/17 Falken A/T4W 1.25" SpiderTrax Spacers BMC, Pinch Weld Folded. C4 High Clearance Fender Liners Performance: OTT Tuned Scan Gauge II for Temp Monitoring Yota Shop Diff Breather Storage Solutions: Sherpa Crestone Sport roof rack Aiden James Customs Gear Plate w/ Slide Out Tables *Backordered. Rado Designs Molle storage panels and top shelf Glove Box organizer Center Console organizer Interior: Diode Dynamics LED Interior lighting (Warm white ftw) Meso Customs Hatch lights Meso Customs Door Handle Covers Ram ball mount for Garmin In-Touch Mini II FitCamX Dash Camera Scosche phone mount Weathertech floor matts Misc: Nano Ceramic Tint (Including windshield and sunroof) Midland MXT575 and Ghost Antenna Cali Raised LED 27W Ditch Lights w/ oem style switch OVS Nomadic 6.5' Awning AVS Low Profile Vent Visors AVS Bugflector II Diode Dynamics puddle lights LasFit Reverse lights LED license plate lights Ark Splash Guards Ark Mud Flap Deletes (cut for rear bumper/ bash bar) AJT Push-To-Start Button +Midland handheld GMRS radios, Baofeng UV-5R Ham radio, recovery gear, water purification system, lifeboat food rations, trauma kit, fire extinguisher and fire starting kit stay on board.
  25. Dec 30, 2024 at 3:12 PM
    Ksny15
    Ksny15 New Member
    Mesa, AZ
    23 TRD Off-Road
    I have them on my 4R. I ran them to my Auxbeam that has a switch pod inside the cabin. Do yourself a favor and get some good quality ones. I would stay away from Amazon.
  26. Dec 30, 2024 at 3:24 PM
    Roger
    I think one needs to be careful when selecting but then it’s Amazon and a crap shoot at times. I’ve been fortunate so far, just about 18 months on these…they’re quite bright (brighter than my DRLs.)
    Raptor Lights on Amazon
  27. Dec 31, 2024 at 9:41 AM
    AE1M
    Bob
    I found it easy to snake an add-a-fuse wire from the low profile fuses out of the fusebox. The lid closes OK and pinches a bit down on the wire. I could just cut a tiny opening there if I want.
  28. Dec 31, 2024 at 9:41 AM
    AE1M
    Bob
  29. Jan 7, 2025 at 6:27 PM
    Sippingonlunch
    Sippingonlunch New Member
    Tim
    2024 SR5 premium
    what spot did you put the raptor light fuse in? I heard people having good luck with using the KDSS fuse if not equipped with KDSS.
  30. Jan 7, 2025 at 8:30 PM
    Hey, don't be messin' with the KDSS fuse, especially for raptor lights. That's double sacrilege.
    Saker likes this.
