Ran out of gas with 1/4 tank showing?
Discussion in '5th Gen 4Runners (2010-2024)' started by Rocko9999, May 5, 2023.
  1. May 5, 2023 at 1:03 PM
    Rocko9999
    Rocko9999 [OP] New Member
    2011 Limited
    So today I ran out of gas with the gauge showing 1/4 tank on my 2011 Limited. Does this sound like a bad fuel sending unit? No codes were thrown.
  2. May 5, 2023 at 1:05 PM
    The sending unit may be sticking. It wouldn't throw a code because there's no fault besides an improper reading.
  3. May 5, 2023 at 1:10 PM
    Just asking but does not one use the trip meter at the same time?
    All our vehicles do have the mile to empty. But at the same time I'm always watching the trip meter. I've seen the miles to empty just drop like mad and guarantee have not driven the miles it said I had left.
  4. May 5, 2023 at 1:21 PM
    I don't use mine. I mean I reset it every tank but I switch back to the odometer. The miles to empty is a best guess but the true fuel level comes from the gauge.
  5. May 5, 2023 at 2:11 PM
    I usually reset the trip odometer every time. If nothing else, it's good to keep track of fuel economy. I would definitely notice if I drove like 400 miles and still saw 1/4 tank on the dash.
    @Rocko9999 do you track your mileage per tank?
  6. May 5, 2023 at 2:13 PM
    5thToy
    5thToy New Member
    Northern Nevada
    2019 SR5P
    Sounds like a bad sending unit. Wouldn’t throw a code. The only system that would know it’s sending a false reading is the driver when he runs out of gas.
    I don’t always reset my trip odometer.
    Rocko9999[OP] likes this.
  7. May 5, 2023 at 2:23 PM
    Rocko9999
    2011 Limited
    Ah. Is this common? Can anything be done short of replacing the entire assembly?
  8. May 5, 2023 at 2:24 PM
    Rocko9999
    2011 Limited
    I do not.
  9. May 6, 2023 at 11:06 AM
    Captain Sensible
    Captain Sensible New Member
  10. May 6, 2023 at 1:26 PM
    08TXRunner
    08TXRunner New Member
    '20 SR5P
    Just throwing this out there in case the obvious - bad sending unit - doesn't fix this. I went through this with my daughter's Tacoma. The shop checked/tested/changed everything and it turned out to be a one in a million issue, the actual gauge cluster. Using a new cluster it worked perfectly. Unfortunately the gas gauge cannot be replaced by itself or repaired, so I had to use a new cluster. It was not cheap.
    Let's hope it's the sending unit.
    2Toys and Thatbassguy like this.
  11. May 6, 2023 at 2:48 PM
    TN_FunRunner
    TN_FunRunner New Member
    Jay
    W. TN
    2018 TRD ORP, 2007 SR5 4WD
    Had this happen on my 4th gen a few years back. Ran a couple of bottles of Techron through it and it hasn’t happened since.
  12. May 6, 2023 at 2:57 PM
    08TXRunner
    '20 SR5P
    How would an additive fix an incorrect gas gauge?
  13. May 6, 2023 at 3:10 PM
    TN_FunRunner
    Jay
    W. TN
    my issue was with the sending unit, it had built up gunk/residue on it over the years I guess.
    Ran out of gas on the interstate and gauge showed around a 1/4. Added more gas, got home added bottle of Techron next two fill ups and hasn’t happened since. not saying my problem and op is the same, just saying what my problem was and have read of others on other forums with similar issues.
    Texrun50 and 08TXRunner[QUOTED] like this.
