Radio Ticking
Discussion in '3rd Gen 4Runners (1996-2002)' started by Marcella123, Oct 21, 2021.
  1. Oct 21, 2021 at 9:55 AM
    Marcella123
    Marcella123 [OP] New Member
    Marcella
    2001 White 4Runner
    Replaced back door
    I've had my 4Runner (it's a 2001 I think??) for a few years now and it's done this the whole time I've had it. Any time I play music, whether it's on a radio station or playing a CD, there's a constant ticking noise coming from the speakers. The noise gets faster with the speed, too. It doesn't happen unless the car is in drive. I have no experience with cars so I don't know where to even start in fixing the problem.
  2. Oct 21, 2021 at 12:30 PM
    PhantomTweak
    PhantomTweak New Member
    Patrick
    OREGON
    1999 4Runner, bone stock
    You need a noise filter in the radio's main power lead. Commercially available everywhere.
    Also, the speaker leads, the actual wire TO the speakers, need to be re-routed. One of them is too close to something feeding noise, electrical noise, that is, into the speaker system. Moving the speaker wires will take care of that. Worst case, a little aluminum foil around the speaker wires, where the speaker wires run near other wires will do the trick.
    Good luck, and let us know how things work out for you!
    Pat☺
    4R21 likes this.
  3. Oct 21, 2021 at 1:16 PM
    Marcella123
    Marcella
    2001 White 4Runner
    Replaced back door
    Thank you so much! I will :)
  4. Oct 22, 2021 at 2:55 PM
    Is this a stock radio system? Stock Speakers? If it is stock, this shouldn't happen. I would be hunting for a bad ground, pinched wire in the radio harness.
    If it's not stock, then good luck, follow the advice above plus consider that the head unit or speakers may be junk.
    Aftermarket equipment is always garbage and the installation is always worse. If I had a dollar for every piece of aftermarket crap I've yanked out of a car where afterwards everything is fixed, I'd be rich.
  5. Oct 22, 2021 at 4:31 PM
    Marcella123
    Marcella
    2001 White 4Runner
    Replaced back door
    As far as I know it’s stock, so maybe I’ll search for a pinched wire like you said
