quick oil change question...
Discussion in '5th Gen 4Runners (2010-2024)' started by acet7, Oct 22, 2021.
  1. Oct 22, 2021 at 5:53 PM
    acet7
    acet7 [OP] New Member
    2021 Dark Grey TRD Off-Road 4Runner
    Tomorrow I'm set to do the first oil change and I tried the search function but couldn't find the answer. Is there a cheat sheet on all of the torque settings for the skid plate, front plastic, oil drain cover etc? I have been watching youtube but most of them skip over this or just use a wrench to tighten. Thanks
  2. Oct 22, 2021 at 5:58 PM
    The Blue Pearl
    The Blue Pearl New Member
    Bill
    16’ NBP 4x4 4Runner
    18’ Tundra SR- 4x4
    You will be fine with a 3/8” ratchet and a nice snug HAND torque - really not that critical
  3. Oct 22, 2021 at 6:03 PM
    BroRunner
    BroRunner New Member
    2015 4Runner Trail Edition
    Edit: this page has all the lubrication system torque specs.
    Transmission & Engine skids are 21 ft-lb.
    Bumper cover is 71 in-lb.
    But I wouldn't treat these as critical and just snug them up with a ratchet and call it good.
    Thatbassguy and acet7[OP] like this.
  4. Oct 22, 2021 at 6:12 PM
    acet7
    you're the man, thank you!
  5. Oct 22, 2021 at 6:13 PM
    BroRunner
    I just updated it. I found the page specific for the "lubrication" system.
  6. Oct 23, 2021 at 7:03 AM
    Pavo
    Pavo New Member
    The only real torque spec is the drain bolt and that's 27 ft lbs everything else is more or less hand tight, oil filter was 18 ft lbs if I remember right
