Questions re bumper hitch steps ...
Discussion in '5th Gen 4Runners (2010-2024)' started by speedmaster, Nov 13, 2020.
  1. Nov 13, 2020 at 6:46 AM
    speedmaster
    speedmaster [OP] New Member
    Have a 2021 RTD ORP and know very little about hitches and towing. Interested in getting one to use a step and maybe prevent minor bumper damage from the rear.
    Would pretty much any one that claims to fit a 2" receiver work on these 4Runners?
    Example:
    https://www.weathertech.com/bumpstepxl/
    Thanks very much in advance!
  2. Nov 13, 2020 at 7:22 AM
    dosomeplowin
    dosomeplowin New Member
    '24 ORP
    Correct- as long as it's 2", it should work. I bought the smittybuilt beaver step a while back and like it. They work as steps and provide some protection against people hitting your car while parallel parking, etc.
    speedmaster[OP] and JET4 like this.
  3. Nov 13, 2020 at 7:26 AM
    Yep, as long as it's 2" it will work
    speedmaster[OP] likes this.
  4. Nov 13, 2020 at 7:47 AM
    speedmaster
  5. Jun 10, 2021 at 11:45 AM
    wolfman
    wolfman New Member
    Bumping an older thread. Anyone have any solutions to stop hitch step rattle? Also, the metal on metal is annoying to hear but also ended up causing rust on a prior vehicle. Would like to not have that happen.
  6. Jun 10, 2021 at 11:55 AM
    iamincrediboy
    iamincrediboy New Member
    South FL
    To fix rattle, something like this is pretty popular: https://www.amazon.com/Rhino-USA-Hi...623351113&sprefix=hitch+rattle,aps,183&sr=8-5
    However be mindful that if your hitch has the two rings on either side to accept the backup chain hooks from towed trailers, some of these hitch rattle reducers wont fit...ask me how I know.
    As for preventing rust, two options are painting the surfaces of all would-be metal on metal, or put something in between them completely - cardboard, plastic, bedliner, etc.
    BilRite and wolfman like this.
  7. Jun 10, 2021 at 1:37 PM
    MeefZah
    MeefZah ------------
    Lexington, Ohio
    2020 GX4(Runner)60
    Someone on here had fitment issues with the Weathertech in the standard 2" receiver... it was like a hair too big or something and wouldn't fit. The one I had, briefly, fit fine though so I'm not sure what the issue was exactly with his.
    I actually found the Toyota OEM draw bar, with no ball mounted, and flipped upside down in the receiver, makes a very nice step and it will shred any fool's radiator that might happen to tap you from behind. Mine came with the truck.
    wolfman likes this.
  8. Jun 10, 2021 at 1:53 PM
    mac1usa
    mac1usa New Member
    I was thinking of applying fluid film to mine and put on a wax application pad. A friend of mine from the forum suggested. I also plan to do this to the bracket where the trailer wires go in.
    Since I have never done this I plan to see how it works in a non visible area first.
    On my old Explorer I had a shop spray it with rubberized undercoating snd it worked great for many many years.
    This would be more difficult on the 4R since you would have to tape off the bumper etal
    wolfman likes this.
  9. Jun 11, 2021 at 10:20 AM
    wolfman
    wolfman New Member
    Thanks for that link! Ordering it. Thanks for the tip. Bedliner would be nice I think but not sure of tolerances for future fit.
    Ah no Weathertech then, thank you. Not sure what yours looks like. Will Google. Thanks!
    Thanks for the suggestions. I feel like Fluid Film wouldn't last very long if both components rubbing. Trying to think of a good thin rubber that I can stretch over it.
