Question on how to install Fang lights
Discussion in '5th Gen 4Runners (2010-2024)' started by Narucalo, Jun 29, 2024.
  1. Jun 29, 2024 at 6:43 PM
    Narucalo
    Narucalo [OP] New Member
    2020 4runner 5th Gen
    Gobi back ladder, raptor lights, trd rims, aftermarket trd front grill.
    I ran into trouble installing the fangs light I got from Amazon. Putting them on was easy but I ended up frying my fuse box and when I did that every maintenance light popped up like I hit the jackpot at the casino. My 4runner now says “Reduce power to the engine, go see your dealership, brake override malfunction” The car starts but stutters, and when I press on the gas it doesn't go anywhere but I can hear the engine revving. I know it has to do with the fuse box but I do not know which fuse to replace.
  2. Jun 29, 2024 at 6:46 PM
    Narucalo
    When I say putting it on was easy I meant to say that take the front bumper off not the wiring part. If it was easy I would not have fried my fuse box.
  3. Jun 29, 2024 at 6:51 PM
    T in Texas
    T in Texas New Member
    FEMA Region 6
    2024 Terra TRD Pro Terra - finally got it
    Where did you pull your power to your 常闭 brand fang lights?
    do you have a OBDII code scanner?
    have you removed the negative battery cable?
    is your vehicle on fire currently?
    kinda need some more info...
    Antiq8ted_Ex0 likes this.
  4. Jun 29, 2024 at 6:58 PM
    Narucalo
    I wanted the Fang lights to turn on when I turned on my normal headlights so I plugged the red wire into those lights slot. It did not do the trick so I just try plugging in every empty slot I see. I use the fuse box near the car engine, not the one inside the driver side. That was a bad idea. I do not have an OBDII scanner. I tried unplugging the car battery for 30 minutes to reset the car's computer. It did not work. The car is not on fire.
  5. Jun 29, 2024 at 7:04 PM
    T in Texas
    FEMA Region 6
    ok, glad the car is not on fire...
    how did you plug into the fuse box near the car's engine?
    did you use a fuse tap?
    wrap the red power wire around one of the fuses?
    have you disconnected the connections you made?
    Ok, I guess you already figured out it was not a good idea to just plug your power wire into every empty slot, so don't do that again...
    did the fang lights work?
  6. Jun 29, 2024 at 7:15 PM
    Narucalo
    I used a fuse tap. My Fang lights came with 3 wires yellow, red, and black. I do not know what that yellow is for so I left it alone, black is ground, and red is power. Red goes into the fuse box. It works but not the way I wanted it just turned on all the time and would not shut off even when the key was out of the car that why I tried randomly into the fuse slot. Back to the more important issue at hand, I know one or more of the fuse are fried is there a machine I can buy to check which fuse are still good and which fuse are fried? That way I can replace the fuse because the car problem now is it doesn't drive anymore when I step on the gas and the power to the vehicle is acting weird like it either has too much power or barely enough to keep it on when I turn on the ignition.
  7. Jun 29, 2024 at 7:25 PM
    T in Texas
    FEMA Region 6
    I understand the important issue now is getting your car working again...
    but we have to figure out what happened, and where the wires went to solve that problem...
    which fuse did you tap into?
    have you removed that fuse?
    most of the fuses in your fuse box, you can just remove ONE AT A TIME and inspected, if the metal band in the center is burned and broken...the fuse is blown
    there are devices to check continuity, but they need a little experience to utilize effectively
    circuit tester?
    multi meter?
    Saker likes this.
  8. Jun 29, 2024 at 8:30 PM
    So did you just have the same two fuses in the “tap a fuse” as you plugged into open slots? That’s important info because If your fuse in the tap was rated higher than the circuit you plugged into, you may have damaged the circuit or anything attached to it.
    By open slots, do you mean you plugged into all the ones without any fuses in? Can you take a picture and indicate which ones you plugged into?
    Did you try plugging into any slots that had fuses in?
  9. Jun 30, 2024 at 6:35 AM
    Narucalo
    Thanks, everybody for the response. I could not afford to miss work so I had to take it to the shop to fix it. I hope to share this experience with somebody who might ever be in the same situation. It will save them some money. So I blew the ETCS 10 amps causing a P2135 code “reduce power to engine and stalling” $185 for the diagnostic, $5 for the fuse $75 for one hour of the mechanic time.
  10. Jun 30, 2024 at 6:42 AM
    My question is did you keep the fang lights or toss them after the fuse fix?
  11. Jun 30, 2024 at 6:50 AM
    I love reading threads about self inflicted wounds that cause serious financial problems. Hitting someone in the wallet is THE BEST way to teach someone what not to do.
    catbrown357 and RUNNER4DAN like this.
  12. Jun 30, 2024 at 7:03 AM
    Narucalo
    Yes, I kept the fang lights I use the fuse tap connect it to the D/L No.1 fuse slot, and insert the original 25A fuse into the lower slot of the fuse tap. Red blown, Yellow is where I install the fuse tap for the fang lights.
  13. Jun 30, 2024 at 10:37 AM
    Thacrow
    Thacrow New Member
    2021 ORP
    Speed holes
    Hey OP. next time you can remove each fuse one at a time. Again, one at a time, replacing it back to where you got it before you move to the next, and visually check if there's a blown fuse.
    Could also use a volt meter.
  14. Jun 30, 2024 at 10:39 AM
    Thacrow
    Thacrow New Member
    2021 ORP
    Speed holes
  15. Jun 30, 2024 at 10:53 AM
    When I click that link it takes me to my previous Amazon orders.
    Thacrow likes this.
  16. Jun 30, 2024 at 12:18 PM
    Thacrow likes this.
  17. Jun 30, 2024 at 12:47 PM
    Thacrow
    Thacrow New Member
    2021 ORP
    Speed holes
  18. Jun 30, 2024 at 1:40 PM
    Posi-Taps are superior to Scotch Loc connectors
    Saker likes this.
  19. Jun 30, 2024 at 1:51 PM
    Ripper238
    Ripper238 New Member
    2019 TRD OR
    Well post a picture of the extremely expensive and potentially catastrophic Fang Lights.
    Thacrow likes this.
  20. Jun 30, 2024 at 7:44 PM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    @Narucalo, guys, isn’t it just a blown 10A ETCS fuse, and a bunch of Mechanic fees?
    I literally blew a fuse and lit up my dash the same way when I was first installing off-road lighting, and one of the keys I found, OP, was to actually ensure that you were resetting the ECU and that you had indeed drained the systems power, by opening a door and disconnecting the lead for even more than half an hour.
    I disconnected lights, replaced a fuse, reset ECU, and fixed the clumsy mistake.
    don’t toss the fang lights LOL just take it as a lesson we all learn all the time man
    T in Texas likes this.
  21. Jun 30, 2024 at 8:22 PM
    T in Texas
    FEMA Region 6
    so what was your mistake?
    so hopefully, I don't make it...
  22. Jun 30, 2024 at 8:30 PM
    I’ve slipped up at least twice, one time was not knowing that the piggyback fuse holder prongs/fuses need to be orientated in the correct direction, and a different time I mistakenly used a 5A in a 10A slot so it just blew after 30 sec. No damages luckily, cuz I wasn’t ever drawing high light loads
  23. Jun 30, 2024 at 8:38 PM
    T in Texas
    FEMA Region 6
    Thanks, I did not know that
    how do you tell which is the correct direction?
    I got some KC cyclones for under hood, is my first lighting project
    I was planning on going direct from battery to a relay, and just using an inline fuse holder between the relay and the switch on the power side
    here is what I got
    https://www.amazon.com/dp/B01DQV2K6Q
  24. Jun 30, 2024 at 9:42 PM
    Thacrow
    Thacrow New Member
    2021 ORP
    Speed holes
    Amazon says those take 5 watts. That means about. 4 amps. Most switches can handle 3 amps or more. Means you don't need to run a relay for these 5 watt lights.
    T in Texas[QUOTED] likes this.
  25. Jul 1, 2024 at 5:01 AM
    Kezin
    Kezin New Member I guess?
    ‘21 and ‘17 Limiteds
    I have those as replacements for my hatch lights. Measured them at 9 watts and 10 watts before installing. Wanted to make sure they weren’t drastically higher than the existing bulbs. That still makes them less than 1A each at 12V. Should be fine going through almost any switch without a relay. 4A would be ~24W each, not the 5W Amazon says.
  26. Jul 1, 2024 at 5:06 AM
    Kezin
    Stories like this one are why I stay away from fuse taps. I wanted the backlights on my SS3 Maxs to be on with DRL and low beam so built a harness coming off the headlight connectors and utilized diodes to keep from back feeding the opposite circuits. Works wonderfully and no unsightly wires coming out of the fuse box either
  27. Jul 1, 2024 at 10:56 AM
    Thacrow
    Thacrow New Member
    2021 ORP
    Speed holes
    I have a tap to ignition on which then turns on a relay connected to the battery.
    This gives me a new ignition on direct from the battery that I have put all my accessories on.
    Just another idea.
  28. Jul 1, 2024 at 10:58 AM
    T in Texas
    FEMA Region 6
    So even coming directly from the battery? I could run direct from battery to switch with no problems? I planned to put an inline fuse of 7.5A before the switch, good idea or no?
    I ordered the kit from etsy to use these lights as replacements for the hatch lights
  29. Jul 1, 2024 at 10:59 AM
    T in Texas
    FEMA Region 6
    I planned that for other lights when I get around to them...
    but for the underhood lights, I wanted ability to switch them on without ignition being on
    good way to drain the battery, but don't plan on using these lights daily
  30. Jul 2, 2024 at 11:22 AM
    Thacrow
    Thacrow New Member
    2021 ORP
    Speed holes
    sorry, longer response. was still waking up before.
    Yeah. Everything comes from the battery. You're just changing where. It's always best to get it directly from the battery if you can or make a new circuit (which is what I did in my car) so that you aren't putting more load on the stock system / circuits which might put more amps on a stock wire or fuse and cause issues with too much load. However small LED's are fine because they don't take much power.
    Think about all devices and things in your car this way - they take as much power as they need or require. Putting something directly to the battery doesn't blast it with more power. The little LED or what ever device it is will only take what it requires.
    You always have to fuse if you're adding a wire from the battery. The only reason you might not need a fuse if you're tapping into the stock electrical is that the stock electrical already has a fuse. You should always fuse as close to the battery as possible in case a positive wire hits a piece of metal in your car. If this is the fang lights I would go 5 amp fuse or even 3. You want to use the smallest fuse possible in case there is a short. On one of my motorcycles I have a 2 and a 3 amp fuse because there's no reason those devices would ever take more than that, unless there's a short on that wire, which is why you have a fuse.
    If you plan to add more accessories in the future you should start looking into what other people have done here in adding relays and fuse blocks, and start planning that now.
    Edit: a thing to consider when adding an accessory off the battery with a switch is that it's hard wired to the battery and the car doesn't need to be on for that accessory to work. So you could accidentally leave the switch turned on and drain your battery with the car off.
    Just throwing this out there for perhaps your long terms plans - I have one of the ignition on wires in my 4runner switch a relay which then turns on all of my switches so that unless my car is on, my switches don't do anything and do not have power so I (or anyone else) can never accidentally drain my battery.
