Question about spacers, neg offset, spindle, off road, and tie rods.
Discussion in '5th Gen 4Runners (2010-2024)' started by Ctreg, Dec 21, 2023.
  1. Dec 21, 2023 at 1:11 PM
    Ctreg
    Ctreg [OP] New Member
    I am conflicted over weather to run some wheel spacers with 33" m/t class e. Worried about the structural degradation on the spindle and tie rods. I am pretty controlled off road and not throttle heavy. Wondering if anyone has an opinion on what kind of added stress an -22 offset would do the aforementioned components? Not rock crawling or racing through the dessert just mud, hills, dips and washout. I like the look and the way it drives with the negative offset just wondering about the added stress.
  2. Dec 21, 2023 at 1:13 PM
    You are correct, wheel spacers can add additional stress to components.
  3. Dec 21, 2023 at 2:13 PM
    catbrown357
    catbrown357 New Member
    Tempe
    2011 Limited 4WD
    Had wheel bearing failure within 10k miles running 1.25" spacers. Do not recommend.
    Toy4X4 and Slopemaster like this.
  4. Dec 21, 2023 at 2:45 PM
    How many miles total on the bearings when they went bad?
    5thToy likes this.
  5. Dec 21, 2023 at 2:58 PM
    The same is true with wheels that poke more than stock. I don’t think it’s going to lead to automatic failures down the line, but it’s fair to say components like bearings will probably wear marginally faster in normal street driving.
    I suspect that offset will make you more likely to break stuff when on crawly type situations, or if driving fast off road. By having your wheels out further, outside forces caused by rocks and holes in the terrain have more leverage over steering components. It’s a good habit to hold on the wheel tightly in bumpy terrain, more so with spacers or wheels with negative offset. If the steering wheel gets wrenched out of your hands, I’d bet the leverage results more potential damage to steering components like tie rods, steering rack, or power steering pump.
    djwantke and Slopemaster[QUOTED] like this.
  6. Dec 21, 2023 at 3:44 PM
    catbrown357
    Tempe
    2011 Limited 4WD
    Well, now that I look at it, 165K. But odd that they went such a short time after the spacer install. And, after I installed the new bearings (OEM) I started to hear humming noise coming from the front end. Took the spacers off, purchased new wheels with the correct offset, no more humming. So, I'm going with the spacers added stress to the wheel bearings by creating a fulcrum between the wheel and the bearing. I know it could be argued that the wheel offset does the same thing, but I think the face of the rotor/bearing mated directly to the wheel lessens the stress on the bearing. I can't mathematically prove it, but maybe someone else can... I went from an 18x9 with a +25 offset with the spacers, to an 18x9 with a -12 offset.
  7. Dec 21, 2023 at 7:54 PM
    I think it’s reasonable that spacers could affect bearing that are already worn in with that many miles, more than they would newer bearings.
    catbrown357[QUOTED] likes this.
  8. Dec 21, 2023 at 8:55 PM
    bassist
    bassist New Member
    2023 TRD Offroad Premium
    Do not hold the wheel with you thumbs inside the wheel when off-road. If something turns your front wheels with enough force, it’ll result in injury.
  9. Dec 22, 2023 at 7:45 PM
    3JOH22A Toyota Gigolo
    You'll have 33" tires steering over a 22mm (almost an inch) wider arc. I'm assuming you've done the cab mount chop and pinch weld hammering to clear the wider arc?
  10. Dec 22, 2023 at 7:55 PM
    Ctreg
    Yes I have BMC, and hammered down my pinch welds.
    djwantke likes this.
  11. Dec 22, 2023 at 8:03 PM
    ^Then feel free to experiment. Spindle and tie rods don't see that much additional stress with the lower offset, and you can always reinforce them - spindle gussets, tie rod sleeves, etc.
    Wheel bearing forces are higher so bearing life is reduced, but it's just one of several factors reducing bearing life. If you drive through deep water or mud, bearing life is reduced too. When purely street-driven, wheel bearings last a long time - my 4Runner with almost 148k miles is on its original wheel bearings. So it isn't a big deal even if life is cut by, say 70%.
    SKF hub/bearing assy is $97: https://www.rockauto.com/en/moreinfo.php?pk=12676781&cc=1445180&pt=1636&jsn=434
  12. Dec 22, 2023 at 10:34 PM
    Ctreg
    That's what I was thinking. I was mainly just worried about sudden catastrophic damage on the trail and being in a remote location. I know that could happen with or with out spacers being run but I was hoping it would be a more of a gradual onset type of damage with signs of failures beforehand. When something is beginning to wear out I am more than willing to replace the part with oem or better after market parts. Sounds like the stresses incurred with a quality 1.5" hub centric spacer should show signs of mechanical failure in advance of instant breakage (hopefully lol). I was wanting to increase my tires width to a floatation size such as 33" 12.5 17" from a plain 285 70 17 to do that I would need the spacers for my uca to clear. BMC is already done.
  13. Dec 22, 2023 at 11:31 PM
    the one thing I noticed going to 285/70-17 was the steering effort increased. Which stresses out the pump. My power steering oil got super hot in extended slow crawly trails this summer, and I could kinda feel the pump get a little lazy. Unless I let things cool down a little. So with wider tires and spacers you might need to be more gentle with what you ask of the pump, to try to keep things cool..
  14. Dec 23, 2023 at 8:19 AM
    ^Add a power steering cooler if you begin to get steering fade. 3rd gen Tacomas has a two-row cooler from the factory, as one of the enhancements over 2nd gen Tacomas. It's however located in an inconveniently low spot, interfering with winch bumper installations.
    You'll be fine. In my experience, wheel bearings on these rigs don't suffer catastrophic failure without warning. You get a groaning noise (like the sound effect before a dragon shoots fire in Game of Thrones) at boulevard speeds well before any physical slop develops, giving you a few hundred miles of driving to get home.
  15. Dec 23, 2023 at 11:12 AM
    A PS cooler should probably be on my list.
    I’m curious what you or anyone else thinks, is overheated PS fluid the primary cause of what kills PS pumps on Toyotas? In other words, if I can keep it cool, would that make the pump sufficient to take the loads of slightly upsized tires?
  16. Dec 23, 2023 at 11:51 AM
    ^Usually the steering rack shits the bed before the pump does. That's why the shortened Tundra rack swap is gaining popularity when upsizing tires. A couple of years ago you had to pull the front diff and weld new mounts into the frame. Now it's all plug-&-play: https://toyo-steering.com/products/5th-gen-4runner-tundra-kit
    Doglover2003 likes this.
  17. Dec 23, 2023 at 1:33 PM
    What’s the failure point on the stock rack? Does the rack fail due to overheated fluid, or is it something mechanical that falls apart?
  18. Dec 23, 2023 at 1:55 PM
    ^Usually the fluid leaks out of the rack ends and you lose power steering assist.
  19. Dec 23, 2023 at 3:06 PM
    Ctreg
    Well I went ahead and put the spacers back on with blue lock tight. Also finished my BMC on the passenger side,cleaned the throttle body, and greased the drive line. I do like the ride on slightly wider stance.
  20. Dec 23, 2023 at 3:34 PM
    Ctreg
    McSpazatron likes this.
  21. Dec 24, 2023 at 5:22 PM
    I think a contributing factor to power steering failures is people don’t do regular fluid flush’s. Contaminated (dirty) fluids can cause seal failures.
  22. Dec 24, 2023 at 5:58 PM
    ^Several contributing factors. Not changing fluid. Using low viscosity fluid. Water can collect in the steering rack boots and cause rust on the output shaft, which in turn chews up the seals.
  23. Dec 24, 2023 at 7:51 PM
    I use the transmission fluid specified in the manual for the power steering system. Are there other compatible fluid options that are higher viscosity that are better in heavy use situations?
  24. Dec 24, 2023 at 8:07 PM
    ^No. Dexron 3 per the manual is the correct fluid. Some people put Dexron 6, Valvoline Max-Life, etc. which are lower viscosity and may lead to leaks.
  25. Dec 24, 2023 at 9:03 PM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    Are fluid flushes snake oil / are the benefits controversial? Or are they always good
  26. Dec 24, 2023 at 9:34 PM
    I’m not a doctor, but isn’t that kinda like asking if kidneys are needed.
    It’s about removing abrasive contaminate’s from the system.
  27. Dec 24, 2023 at 10:12 PM
    Generally, sure, but I've heard some ppl say engine oil flushes aren't needed but oil change shops push them cuz they certainly bring in money
  28. Dec 24, 2023 at 10:45 PM
    True, seems that if it was a big problem, they would have incorporated a filtering system.
    djwantke[QUOTED] and backpacker like this.
  29. Dec 25, 2023 at 5:54 AM
    Back to offset for a minute......
    Are those with Pro wheels going through wheel bearings faster than those with stock SR5 and Offroad wheels? I seriously doubt it.
  30. Dec 25, 2023 at 8:57 AM
    Ctreg
    Great point.
