Question about air pump and EGR
Discussion in '5th Gen 4Runners (2010-2024)' started by Mojave, Aug 28, 2023.
  1. Aug 28, 2023 at 1:25 PM
    Mojave
    Mojave [OP] New Member
    zeak
    az
    5Th Gen 4Runner trd off Road
    I noted the two air pumps on top of valve covers for emissions. are they for egr system ? dose our engine have an egr system?
  2. Aug 28, 2023 at 1:27 PM
    They're secondary air injection valves to bring the cats up to temp faster and hotter. There is no EGR on this engine. The pump is the whistle you hear on startup and shutdown. Look into replacing the foam filter with a clamp on because the foam can break down and get sucked in.
    Agent_Outside, 2Toys and Mojave[OP] like this.
  3. Aug 28, 2023 at 1:40 PM
    Mojave
    zeak
    az
    Thanks whippersnapper. so glad theres no egr, that's why our engines lase so long. regarding foam filter, is that in the air pump?
  4. Aug 28, 2023 at 2:08 PM
    It's just under the cover. I removed mine and replaced it with a dry Uni clamp on filter.
    2Toys and Mojave[QUOTED][OP] like this.
  5. Aug 28, 2023 at 6:28 PM
    rmiked
    rmiked New Member
    Fort Mill, SC
    Any more details on how replace that filter? I have not looked at the cover details? Just remove a few bolts? Where get the dry Uni clamp on filter?
