Quality brake kit?
Discussion in '4th Gen 4Runners (2003-2009)' started by gr@yw0lf, Mar 15, 2024.
  1. Mar 15, 2024 at 11:16 AM
    gr@yw0lf
    gr@yw0lf [OP] New Member
    04 v8 four runner 4wd
    None yet
    need to order complete brake kit quality and price are important and tips where?
  2. Mar 15, 2024 at 11:58 AM
    xtremewlr
    xtremewlr New Member
    Todd
    Tucson, AZ
    2003 4Runner V8 Limited 4WD
    Lots with more in the works
    rockauto.com will have all you need. Good prices and they carry quality products.
  3. Mar 15, 2024 at 2:03 PM
    AuSeeker
    AuSeeker Old As Dirt
    Skip
    South Carolina
    2004 Limited
    You will need to know what size front brakes you have before ordering!!
  4. Aug 16, 2024 at 6:09 AM
    AnchorSean
    AnchorSean New Member
    Sean
    Huntington WV
    White 2006 4runner Sport Edition
    I am in the same boat. I need to change the front brakes and rotors on my new to me 2006 V8 Sport Edition. I have been looking at a couple different options, one of which is a Surestop pad and rotor kit but it's available with two different rotor sizes. My question is what size rotor do I have, there seem to be two options 319mm and 338mm diameter. I have been trying to do my research on line but keep running into conflicting information. Any help will be appreciated.
    By the way, I went to Advance Auto Parts website and entered my VIN but their site identifies my runner as an SR5 which it is not so I don't feel like I can trust what they recommend.
  5. Aug 16, 2024 at 7:23 AM
    BLKNBLU
    BLKNBLU New Member
    2019 TRD OR Nauti Blue
    Try entering your VIN on a Toyota OEM site and see what part number it spits out. Then cross reference that to RockAuto.
  6. Aug 16, 2024 at 7:38 AM
    Bluesky 07
    Bluesky 07 Not a New Member
    Russell
    Northern Georgia
    Silver ‘07 Sport V6 4WD @ 263K miles
    “Deep” Satoshi grille | X-REAS delete / TRD Offroad front springs & Bilstein 4600 shocks + FJC rear springs | Weathertech front & rear mats | Tinted front windows | Floor Armor cargo mat | TPMS bypass | LED interior, tag, & reverse lights | BlueSea Systems console USB power ports | Gentex 453 autodim mirror w/Homelink & compass | Kenwood DDX373BT HU + Audiovox backup camera | Fumoto F-103S | Bazooka tube subwoofer | Kenwood speakers & KAC-M1804 amp | Philips H9/9011 headlight bulbs | Rexing V1 Gen3 dash cam | Map light mod | Breather mod | Off-road Nav Setup | Power Stop Z36 brakes | OBD Fusion diagnostics
    Sport Edition has the larger 338mm front rotor. PowerStop makes a nice kit (Z36) but compare online prices on Toyota's parts site. I went all OEM last time (2022) for about the same as I would have spent on another PowerStop set. Parts list below for my '07 Sport but verify fitment for your vehicle by entering your VIN at parts.toyota.com.
    Once you put in your zip code and find a part, the Toyota parts site will present a list of dealers in your area. Be sure to check pricing at each one. Some charge MSRP but others offer a significant discount for buying online and you can often get free shipping or just pick it up at the dealer parts department.
    Brakes parts list:
    049450C030 1 $ 15.30 SHIM KIT, ANTI SQUEAL, FRONT
    0494630100 1 $ 15.30 SHIM KIT, ANTI SQUEAL(FOR REAR DISC BRAKE)
    0446660090 1 $ 44.37 Disc Brake Pad Set (Rear)
    04465AZ200 1 $ 38.76 Disc Brake Pad Set (Front)
    4351260151 2 $ 52.75 Disc Brake Rotor (Front)
    4243160201 2 $ 67.21 Disc Brake Rotor (Rear)
    $353.65 plus $21.22 tax = $374.87 picked up (but shipping would have been free anyway)
    Other than price maybe, I don't know why people don't just stick with OEM. The pads are pretty beefy and the performance is great.
  7. Aug 16, 2024 at 11:38 AM
    AuSeeker
    Skip
    South Carolina
    2004 Limited
    If you want to know for sure just measure the rotor, the 319mm is 12.5591 inches, so a tad over 12 1/2", the 338mm is 13.3071, so a tad less than 13 1/2", so there's just under 3/4" difference, so if you rotors are over 13" they're the 338mm, less than 13" they're the 319mm, easy way to get it right the first time!
    That only the fronts, the rears are the same size for all 4th Gens.
    xtremewlr likes this.
  8. Sep 23, 2024 at 7:42 PM
    RustyTr4ils
    RustyTr4ils New Member
    2003 4Runner Sr5
    I recently swapped out my seized rear calipers for powerstop. Much smoother and stronger braking.
