Problem with ch4x4 small push switch
Discussion in '5th Gen 4Runners (2010-2024)' started by diverdon, May 16, 2021.
  1. May 16, 2021 at 5:26 PM
    diverdon
    diverdon [OP] New Member
    Don
    Florida
    21 t4r sr5 premium
    Has anyone had any issues with the ch4x4 push switches? I’ve used them in my Tacomas without any problems but in my 4Runner I have to push real hard to actuate the switch
  2. May 16, 2021 at 6:11 PM
    What push switches are you talking about?
    My SR5 has a rotary knob to put into 4 wheel drive and the OR has the traditional shifter.
  3. May 16, 2021 at 7:41 PM
    memario1214
    memario1214 Hotshot Offroad Staff Member Vendor
    Colton
    Missoula, MT
    Is it perhaps binding in the truck's bezel? If you pull it out and try to depress it do you get the same resistance?
    Could be a bad switch.
  4. May 17, 2021 at 6:05 AM
    What exactly is a ch4x4 switch?
  5. May 17, 2021 at 6:17 AM
    kbp810
    kbp810 rebmem wen
    Ch4x4 is the company name; Aftermarket OEM style push button switches for adding lights and other stuff. They fit into the existing blank switch spaces.
    I’ve had this happen with other brand switches, where is was the switch itself (even uninstalled it was hard to engage), but have had good luck personally with ch4x4 ones. As said above, could be catching on something, or could just be a bad switch.
  6. May 17, 2021 at 6:21 AM
    Thank you. I get it now. It seems I wasn't the only one confused by the 4x4 bit...
  7. May 17, 2021 at 6:28 AM
    iamincrediboy
    iamincrediboy New Member
    South FL
    Just to say... the only switch brand I have ever seen on this forum no less with consistently bad reviews is CH4x4. People get anywhere from a couple weeks to a few months of use, then the switch binds, doesn't actuate, all sorts of issues.
    Spend the couple extra dollars and get AirOnBoard or OTRATTW switches and know you're getting good switches.
  8. May 17, 2021 at 6:35 AM
    diverdon
    Don
    Florida
    21 t4r sr5 premium
    I’m going to look at the otrattw shitches
  9. May 17, 2021 at 6:57 AM
    diverdon
    Don
    Florida
    21 t4r sr5 premium
    Having trouble finding a different switch that fits in the factory spots
  10. May 17, 2021 at 7:00 AM
    doublewide
    doublewide ShittCo
    TRD OR PREM
    diverdon[OP] likes this.
  11. May 17, 2021 at 7:56 AM
    diverdon
    Don
    Florida
    21 t4r sr5 premium
    Just ordered some push switches from AOB
    iamincrediboy likes this.
  12. May 17, 2021 at 9:13 AM
    GrayGhost
    GrayGhost New Member
    Dave
    2020 orp - sold
    I had ch4x4 as well as seen others had the same issue. Mine would stick and needed a smack to free it up. Tossed them and went air on board and they have been problem free almost 2 years now
  13. May 17, 2021 at 9:21 AM
    diverdon
    Don
    Florida
    21 t4r sr5 premium
    Good to know
  14. May 17, 2021 at 1:07 PM
    kbp810
    kbp810 rebmem wen
    I wish OTRATTW offered Toyota style push button switches... if you ever need a contura/rocker switch, that's def the way to go.
    Honestly, I have a feeling that Cali Raised, CH4x4, and AOB probably all get their switches from the same source; and it's just a matter of getting good ones or some from an unlucky bad batch. I've seen such a mix of reviews on all of them over the years that it leads me to that hunch. Or just the nature of the small sized switch and style make it a difficult one to reproduce consistently.
  15. May 17, 2021 at 2:31 PM
    markmb45
    markmb45 New Member
    South Ogden, Utah
    2013 4Runner Trail Edition
    3” OME Lift, JBA UCA’s, 275/70R17 General Grabbers, ARB air compressor
    My compressor switch was sticking. The switch cover was binding on the 4Runner mounting location when depressed. Clearance was too tight. Filed a slight bevel on the switch top and bottom. Problem solved.
  16. Nov 17, 2022 at 6:17 AM
    Switch Master
    Switch Master New Member
    WILL
    2022 LIME RUSH 4RUNNER TRD PRO
    NONE AS OF TODAY
    must 4runners have a piece of plastic in the OEM whole that need to be filed down if your switches are not staying depresed is for all aftermarket push switches not only CH4X4
  17. Nov 20, 2022 at 7:38 AM
    MAXIM
    MAXIM New Member
    I had same issue. Your CH4x4 switch is fine. Take it out and look at stock trim opening. Panel opening for switch has few small protrusions. Take a blade or wood chisel to it and shave those down flat with opening. Reinstall the switch and you are all set. G.L.
    Switch Master likes this.
