Prinsu Roof Rack Questions
Discussion in '5th Gen 4Runners (2010-2024)' started by bhcjdabv, Jan 29, 2023.
  1. Jan 29, 2023 at 2:02 PM
    bhcjdabv
    bhcjdabv [OP] New Member
    Brandon
    2023 4Runner SR5 Premium
    Just purchased a full length Prinsu rack for my T4R and I've scoured the forum and the internet in general looking for information on this rack in particular or any other aftermarket roof racks. Lots of information on pros/cons/how they look after, but not much information on the install side of things.
    I was hoping to hear about some of your experiences in installing your aftermarket roof racks, and mainly "what you wish you knew then" looking back on it. Also looking for any feedback on waterproofing, types of silicone, alternatives to silicone, etc.
    Any information would be much appreciated, as I'd like to be as prepared as possible when the new rack comes in this week!
  2. Jan 30, 2023 at 8:36 PM
    LA260
    LA260 New Member
    I installed the Prinsu full rack on my 4runner using butyl tape and PTFE on the bolts and no silicone. Also I added washers (3/8 I think) under the spacers provided by Prinsu. I don't have lots of pics but u get the idea. It's been 2.5 years and my car had been through some serious weather plus it's been always pressure washed and so far no leaks anywhere.
    bhcjdabv[OP] likes this.
  3. Jan 31, 2023 at 5:59 AM
    Braumeister
    Braumeister Kampai, bitch!
    Bentley
    Northern MI
    2021 TRD Off-Road Premium
    Installed mine with a low profile light bar last year and have been very happy with it. Went with an aluminum rack like the Prinsu because our salty Michigan roads destroy steel. Also very happy with the versatility and the lack of wind noise.
    I wish I had been a bit more careful when prying off the factory roof rack’s plastic boots as I now have two small dents on the roofline that scream at me every time I look at them. I followed the instructions using silicone caulk and I’ve had zero leaks.
  4. Jan 31, 2023 at 5:44 PM
    bhcjdabv
    Brandon
    I read a few horror stories with those plastic boot removals, I plan to be super careful. Thank you! I think I’ll be going the silicone route as well
    (thanks for all of the feedback everyone!)
  5. Jan 31, 2023 at 6:28 PM
    Roothog
    Roothog New Member
    2021 ORP
    I used J-B Weld 31319 RTV Silicone Sealant and Adhesive found at Amazon. There are several YouTube videos that show the install process. I must have watched them all 5 times each waiting for the Chocolate Santa to deliver my rack. Use a plastic panel tool and laid down a folded micro fiber towel when removing the plastic end covers. I also layed down a strip of Clear Paint Protection Vinyl Film 4" x 48" where the strip from the noise reduction trim hits the paint on the front wind deflector. I'm very happy with the Prinsu rack.
  6. Feb 1, 2023 at 4:39 AM
    bhcjdabv
    Brandon
    I was looking at some RTV as well, just trying to find the right clear one. And yes I watched a few install videos, but all were replacing previous aftermarket so the silicone job was done already. I’ll go find one that shows that part as well to make sure I know what I’ll have to do.
    Did anyone have issues with cutting their weather stripping? I’m debating the need to borrow a Dremel that I don’t currently have, or if heavy duty scissors will work?
  7. Feb 1, 2023 at 10:05 AM
    Roothog
    Roothog New Member
    2021 ORP
    I used heavy duty scissors, it's not that difficult to cut thru.
    Install videos
    www.youtube.com/watch?v=zT7wTUId2C4
    www.youtube.com/watch?v=B3NWMsCR_ZE
    www.youtube.com/watch?v=2N4mV34vWPk
    Hope these videos help.
    bhcjdabv[QUOTED][OP] likes this.
  8. Feb 1, 2023 at 1:59 PM
    Cypher_Systems
    Cypher_Systems New Member
    J.r
    20' Super White 4Runner
    Eibach Pro-Truck Lift - Stage 2 Black Rhino 17 x 9.5 Nitto Ridge Grapplers 295/70/17
    I've had my rack on for about a month. Installed it in 20 degree temps outdoors. Everything buttoned up fine and its solid.
  9. Feb 16, 2023 at 1:13 PM
    rrprouty
    rrprouty New Member
    Ryan
    2019 SR5P, 2016 Limited
    has anyone added any extra silicone to the negative space left AFTER the install is complete. Or would this cause pooling or something else?
  10. Feb 17, 2023 at 6:02 AM
    Fisch
    Fisch New Member
    Jacksonville, Fl
    2018 TRD ORP
    Empty wallet
    I didn’t use silicone, but I reused my OE bolts that had the rubberized washers on them. No issues or leaks. I’m in Florida where it rains everyday at 4pm.
  11. Feb 17, 2023 at 6:15 AM
    rrprouty
    rrprouty New Member
    Ryan
    Interesting... I have watched like 20 install videos and I dont think Ive seen a single one do that!
    So do you put the washer UNDER the spacer that come with the rack? Between the actual roof and the black cylinder?
  12. Feb 18, 2023 at 5:50 AM
    Fisch
    Fisch New Member
    Jacksonville, Fl
    2018 TRD ORP
    Empty wallet
    Negative. I didn’t remove the rubber grommet from the OE bolt. I just installed on top of the fender washer.
    again zero water intrusion.
    5E35F9CD-D704-4C0C-ACDE-D3ECCDFF4DDA.jpg FE2C8DB8-56B2-44E5-95C0-0A7897352F6A.jpg
  13. Feb 20, 2023 at 10:19 AM
    rrprouty
    rrprouty New Member
    Ryan
    oh i see! so go about using teh silicone like normal on teh bottm but that rubber ring will keep water from leaking into through the top. got it! good idea!
  14. Feb 20, 2023 at 8:08 PM
    Fisch
    Fisch New Member
    Jacksonville, Fl
    2018 TRD ORP
    Empty wallet
    You could, but I did not. No silicone used.
  15. Feb 21, 2023 at 9:41 AM
    I wonder why people keep insisting on using silicone, when it has been said over and again that butyl tape is the preferred sealant to use...
    grizzlypath likes this.
  16. Feb 21, 2023 at 10:47 AM
    rrprouty
    rrprouty New Member
    Ryan
    every install video (even from mfg) use silicone.
  17. Feb 21, 2023 at 11:00 AM
    MyWyfsRnnr
    Chris
    Citrus Heights
    2018 4Runner TRD
    Fisch and rrprouty like this.
  18. Feb 21, 2023 at 5:28 PM
    Fisch
    Fisch New Member
    Jacksonville, Fl
    2018 TRD ORP
    Empty wallet
    MyWyfsRnnr[QUOTED] likes this.
  19. Sep 19, 2023 at 11:27 AM
    ialexyoung
    ialexyoung New Member
    I assume you heated up the butyl tape before placing it? Similar to installing a new cover on a headlight fixture?
