PowerStop Brake Upgrade Kit
Discussion in '5th Gen 4Runners (2010-2024)' started by Rick G., Jan 22, 2025.
  1. Jan 22, 2025 at 9:14 PM
    Rick G.
    The Texas Hill Country
    2022 SR5 Premium 4WD
    I’m getting a sense that my brakes on my 2022 SR5 Premium 4WD feel weak, or marginal. I’m at 37,700 miles.
    The brakes are not noisy, nor do they pull to either side when braking, but I feel the need to replace them, if only the fronts at this time. The factory pads are nowhere near worn out.
    I stumbled across a YouTube video showing a guy replacing his front brake pads AND rotors, with this kit from a company called “PowerStop”. The rotors are drilled, and slotted. He used their stock # Z36 kit.
    Has anyone here tried these PowerStop brand brakes on their T4R and have anything good or bad to say about them? They ain’t cheap, I’m wondering if they’re worth it, and whether or not I should pony up and do the rear brakes as well, or if just doing the fronts will suffice. I’m not hauling or pulling heavy loads, just driving around with an empty vehicle the majority of the time. Thanks for reading.
  2. Jan 22, 2025 at 9:19 PM
    If it ain’t broke, why fix it. I always thought drilled and slotted rotors weren’t recommended for off road vehicles because they can hold mud and debris.
    Saker, 2016Pro, Thatbassguy and 5 others like this.
  3. Jan 22, 2025 at 9:50 PM
    The OEM brakes are good. 4 piston fixed calipers that not even my GTO has from factory. I played the rotor and pad game on my Tacoma and got nowhere. I would go with a larger rotor and caliper for increased heat capacity but until then OEM.
    Slopemaster likes this.
  4. Jan 23, 2025 at 1:47 AM
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    2016 4Runner TRD Pro
    I have the Z36 kit. I notice zero change over stock. I bought it because my rear brake pads needed replacing and I thought F it, I'm going to spend some coin and "upgrade".
    I don't tow or haul with my 4Runner. If I could do it all again, it's a coin toss if I'd make the same decision.
    Ironguy likes this.
  5. Jan 23, 2025 at 1:49 AM
    Toy4X4 and BS67 like this.
  6. Jan 23, 2025 at 4:50 AM
    coachhomer
    coachhomer New Member
    Have to echo this. I changed the brakes on my Ford Raptor to the same kit and didn't notice a thing.
  7. Jan 23, 2025 at 5:01 AM
    Shanky
    Shanky New Member
    If you off-road, slotted rotors do fill up with mud & dirt.
  8. Jan 23, 2025 at 5:26 AM
    Agent_Outside
    Built 2011 T4R Limited
  9. Jan 23, 2025 at 5:59 AM
    1SilverRunner
    1SilverRunner My boy, blue
    Tejas
    22 TRD Off Road Premium
    Front Bumper: C4 Fabrication Low-Profile Bumper Warn Evo10-S Winch w/ Warn wireless adapter Extreme LED dual color light bar w/ Cali raised LED OEM style switch Bumper Cover Trimmed For Clearance Rear Bumper: 80% Off Road Rear Bash Bar (Limited rear bumper version) Armor: RCI Skid plate package C4 Gas tank skid RCI Rear diff skid RCI Shock Skids RSG Angled/ Plated Sliders Total Chaos Cam Tab Gussets Total Chaos Spindle Gussets 41.22 Hitch Slider Suspension: Dobinsons IMS long travel shocks: (Front: IMS59-50574 w/ C59-352 Springs) (Rear: IMS59-50575 w/ C59-677v Springs) Apex Chassis Tie Rod Assemblies (KIT410) Apache Off Road UCAs Apache Off Road HD Rear Links (Upper and Lower) Apache Off Road Rear Sway Bar Links Dobinsons Track Bar Front Sway Bar Deleted DuroBumps Rear Bump stops PerryParts Front Bump stops DRKDSS Track Bar Correction kit Dobinsons Diff Drop Wheels/ Tires: RRW 17x8.5 -12 RR6-H Wheels 285/75/17 Falken A/T4W 1.25" SpiderTrax Spacers BMC, Pinch Weld Folded. C4 High Clearance Fender Liners Performance: OTT Tuned Scan Gauge II for Temp Monitoring Yota Shop Diff Breather Storage Solutions: Sherpa Crestone Sport roof rack Aiden James Customs Gear Plate w/ Slide Out Tables *Backordered. Rado Designs Molle storage panels and top shelf Glove Box organizer Center Console organizer Interior: Diode Dynamics LED Interior lighting (Warm white ftw) Meso Customs Hatch lights Meso Customs Door Handle Covers Ram ball mount for Garmin In-Touch Mini II FitCamX Dash Camera Scosche phone mount Weathertech floor matts Misc: Nano Ceramic Tint (Including windshield and sunroof) Midland MXT575 and Ghost Antenna Cali Raised LED 27W Ditch Lights w/ oem style switch OVS Nomadic 6.5' Awning AVS Low Profile Vent Visors AVS Bugflector II Diode Dynamics puddle lights Diode Dynamics 921 XPR Reverse lights LED license plate lights Ark Splash Guards Ark Mud Flap Deletes (cut for rear bumper/ bash bar) AJT Push-To-Start Button +Midland handheld GMRS radios, Baofeng UV-5R Ham radio, recovery gear, water purification system, lifeboat food rations, trauma kit, fire extinguisher and fire starting kit stay on board.
    As others stated I wouldn't recommend drilled and slotted rotors for the 4Runner.
    I do have some personal experience with Powerstop. Added their rotors to my Subaru STi a few years back. They warped within a couple of weeks.
    Upgraded to DBA rotors based out of Australia and they held up great even through my abuse.
    I'd stick with OEM unless you've added a lot of weight and need larger rotors and calipers. Which is a very expensive option.
  10. Jan 23, 2025 at 7:06 AM
    Charlievee
    Charlievee Not new member.
    Fluid change and bleeding was the first step i did. Added some new Akebono pads and they are good enough for now. I was looking at going with a six piston setup but for the price, i'm holding off.
    TrailSpecial22 and 1SilverRunner like this.
  11. Jan 23, 2025 at 7:29 AM
    I’ve used power stop rotors and pads on a few vehicles, not the 4Runner though. I had no issue with them and did see some improvement in braking. I think that is most likely due to the pad compound rather than the slotted rotors. A standard rotor with a more aggressive pad is probably the best route for the 4Runner.
  12. Jan 23, 2025 at 7:40 AM
    2021venture
    2021venture New Member
    Todd
    2021 Venture
    1SilverRunner likes this.
  13. Jan 23, 2025 at 9:59 AM
    MEski4x4
    MEski4x4 New Member
    2024 TRD Pro
    Drilled & slotted rotors decrease surface area of the rotor - you will have better performance with stock rotors than aftermarket drilled & slotted. Larger solid rotors will make a difference, but it won't be super measurable. These vehicles aren't creating enough heat to benefit from a slotted or dimpled rotor
    alittleoff likes this.
  14. Jan 23, 2025 at 11:07 AM
    alittleoff
    alittleoff New Member
    Steve
    406
    '16 TP
    For my Nephews birthday (the day after Xmas), I bought him some engine and safety related parts for his Nissan Frontier.
    One of those things was stock rotors and pads from Rock Auto, to replace the brand X, drilled/slotted disc's and metallic pads.
    They were filthy and packed with junk. After fresh fluid and a good bleeding and a proper bedding, he reports a solid pedal and strong stopping power.
    He always appreciates the practical B-day gifts that my Wife and I give him. And he also Auto-crosses with his 280Z so he likes the fancy stuff for that since it doesn't see much street use.
  15. Jan 23, 2025 at 1:45 PM
    Thacrow
    Thacrow New Member
    2021 ORP
    Speed holes
    I had an Eclipse when I was a young man. Wanted a big brake kit. Someone talked me into getting really nice brake pads. Glad they did because it was world's of difference. Insanely more stopping power. I just had to replace them every 10k miles.
    I would try EBC or Hawk brake pads first and see how it goes.
    When weighted down going camping or off roading braking at highway speeds feels fairly anemic and I've been meaning to try pads out first before dishing out thousands on a big brake kit.
    Also a few months ago I got stuck in the mud. In trying to get out the rocks in the thick mud scraped up the I side of some of my wheels and tore the weights off. Caked mud in the brakes and would have scraped to shit some nice looking big brake kit which would probably just be for show since some nice pads will probably do everything we need.
  16. Jan 23, 2025 at 2:00 PM
    Lost Woods
    Lost Woods New Member
    This right here, and if you think you've heard brake squeal, you haven't heard it until that dirt and shit gets embedded in the pads.
  17. Jan 23, 2025 at 4:11 PM
    I have Powerstop pads on otherwise stock brakes. I like to think they're an improvement over the stock pads, but I'm not sure if it's just in my head. I will say that, even with a bunch of extra full-time weight, I am regularly impressed by how good the brakes are on this vehicle.
  18. Jan 23, 2025 at 4:44 PM
    What is the exact symptom you feel indicating "weakness"? A lot of pedal travel before the brakes grab? A different pad compound can help. Don't know which one though.
    Going to a larger caliper with larger pistons or more pistons can make the pedal travel longer - basic fluid mechanics. And with the electronic booster, there's no easy upgrade path with Tundra/Sequoia boosters.
    Slotted rotors are good for keeping the pad surface clean and evacuating water, but in my experience on 4 vehicles, don't increase initial bite.
  19. Jan 23, 2025 at 6:08 PM
    DesertSurfer
    I let my son (Certified Toyota Master Tech) drive my 4Runner after I purchased it. He came back and said you have air in your brake system. I said “bullsh$t” it’s a brand new vehicle, it stops good, forget that. Next day he brought over a power bleeder and his Carista, which looked like an iPad to me. 30 minutes later he said to take it for a drive. I came back with a sh$t eating grin on my face and said wow, the brake pedal starts way higher on its stroke down and now it stops on a dime. He said on the ship over it might have encountered some rough seas and bounced around enough to get some air in the master cylinder, then into the lines.
  20. Jan 23, 2025 at 6:36 PM
    TrailSpecial22 New Member
    PA
    i have used the Z36 pads on my 2011 with stock flat rotors and love them. Once the stock pads go on my 2022, i have a z36 set waiting to swapbin
  21. Jan 28, 2025 at 5:08 AM
    Greg D
    Greg D New Member
    Greg
    2013 4runner
    I have used Powerstop brakes last 20+ years and excellent upgrade. Haven't warped a rotor yet on emergency lock down. You do have to seat them per instructions, but no fade or marshmallow pedal. Good upgrade if you tow or haul. Great if you don't. My rear driver pads seem to wear more quickly than front pads so keep an eye on rears before front.
  22. Jan 28, 2025 at 5:26 AM
    aroyalsfan
    aroyalsfan The Owner
    Kansas City
    I have this kit front and back. I've been happy with them. Of course I told my wife it would only take me 2 hours to do all 4....but hey it worked out when I finished up many hours later it was dark and no cars on the road. Perfect for bedding them.
  23. Jan 28, 2025 at 5:49 AM
    Greg D
    Greg D New Member
    Greg
    2013 4runner
    My parking brake retainer spring came off with a rotor and that was 30 minutes of two people cussing it back together. Nightmare
    3JOH22A and TrailSpecial22 like this.
  24. Jan 28, 2025 at 9:15 AM
    2016Pro
    Oem, no slotted or drilled junk
  25. Jan 28, 2025 at 9:42 AM
    Gumpus
    Gumpus New Member
    4Runner brakes have more pedal travel than many vehicles. If you're used to vehicles with no pedal travel it's understandable that you might perceive pedal travel as weak brakes. You can also look at it as easier to modulate the amount of braking you apply. 4R's also have soft, predictable response to the throttle pedal. Some folks perceived this as feeling slow and get a Pedal Commander to make it more responsive, others are happy with the more predictable response which is for sure better offroad and on slick surfaces. Unlike 99.9% of vehicles out there, 4R is actually designed to go offroad.
  26. Jan 28, 2025 at 10:15 AM
    surfingbuddhist
    surfingbuddhist New Member
    Glen
    2020 4Runner
    I have this kit. Installed at 60k miles and I love the way the new discs look over the OEM discs which were at the end of their life. The Powerstop pads are not that great over stock in terms of performance and very dusty. On my 3rd set of front pads now since the new discs. The second set were EBC green and those were junk - worse stopping power, super dusty and didn't last long. Now I'm using Porterfield R4-S pads which are great. Noticeable stopping power and super low dust. The Powerstop discs with Porterfield pads are a great combo. I do light offroading (desert and mountains in SoCal) but never drive my car thru mud that would affect the drilled/slotted discs.
    https://porterfield-brakes.com/search-result/?years=2020&make=58&model=2027&manufacturer=7444
  27. Jan 28, 2025 at 12:23 PM
    KillerInsideMe
    KillerInsideMe New Member
    Scott
    2019 4 Runner Nightshade
    I feel like brake "weakness" is a personal perspective. I'm curious what your frame of reference is, like what did you drive before or what is your second car if you have one?
    My last ride was an 05 Sequoia... This 19 4 Runner stops like a fking race car by comparison, so I have zero interest in trying to change that or improve on it.
  28. Jan 28, 2025 at 12:32 PM
    surfingbuddhist
    Glen
    2020 4Runner
    IMO the 4Runner brakes are weak. I recently rented a new Toyota Corolla when on vacation and every time I touched the brakes almost locked them up because I was applying the pressure to the pedal as I'm used to on my 4Runner until I got used to how much better those brakes were.
    jasonmcelroy likes this.
  29. Jan 28, 2025 at 12:50 PM
    A Corolla weighs a lot less and should stop better.
    2016Pro and alittleoff like this.
  30. Jan 28, 2025 at 12:55 PM
    surfingbuddhist
    Glen
    2020 4Runner
    Doesn't change the fact that 4Runner brakes are too weak for me. Brakes will stop you, but I prefer a firmer, harder braking system. If we only made a kit to fit under a 17" wheel...
    This is how I know:
