Power window relay 2010 4Runner
Discussion in '5th Gen 4Runners (2010-2024)' started by Dave Tabs, Aug 30, 2024.
  1. Aug 30, 2024 at 11:42 AM
    Dave Tabs
    Dave Tabs [OP] New Member
    2010 4Runner SR5
    None
    Driver’s side power window not working. All others work. I’ve checked the master switch, window motor, and fuses.
    Relay seems like the next step.
    Which relay controls the drivers window?
    PS: the passenger airbag light started non-stop flashing at the same time the window went kaput. Coincidence?
  2. Sep 1, 2024 at 7:35 PM
    Dave Tabs
    2010 4Runner SR5
    None
    It is a g’darn mystery
    Rechecked all fuses
    Everything is getting power except the drivers window
    Even the night lights on the switch is out
  3. Sep 4, 2024 at 7:12 PM
    Dave Tabs
    2010 4Runner SR5
    None
    What about the body control module? Anyone?
  4. Sep 18, 2024 at 7:27 AM
    Dave Tabs
    2010 4Runner SR5
    None
    Solution/Resolution:
    I took it to a specialty automotive electronics shop. They discovered that I once had a small leak and water had settled and rusted some electrical connectors. They cleaned and dried then out…removed some rust and the window hit back on-line. Thanks to the community for help and support!
    JET4 likes this.
