Power window problem. HELP!
Discussion in '5th Gen 4Runners (2010-2024)' started by jonbert, Aug 22, 2024.
  1. Aug 22, 2024 at 10:38 AM
    jonbert
    jonbert [OP] New Member
    My 2011 SR5 Driver door and rear hatch window stopped working. I purchased a new window/lock control, plugged it in and still nothing. All other windows work including the rear hatch window with the key. Fuses seem to be ok. Any suggestions?
  2. Aug 22, 2024 at 10:46 AM
    The motors are probably dead.
  3. Aug 22, 2024 at 10:49 AM
    Lc200
    Lc200 New Member
    Pre Facelift SR5P
    The motors are gone.
  4. Aug 22, 2024 at 11:23 AM
    If both of these things happened at the same time, I’d be suspicious of something other than the motors.
  5. Aug 22, 2024 at 12:46 PM
    Noodles
    Noodles New Member
    If it works with the key it’s the switch and not the motor.
    jonbert[OP] likes this.
  6. Aug 22, 2024 at 1:00 PM
    Manhattan
    Manhattan New Member
    Does the rear window go up/down using the key on the tailgate?
    Does the rear wiper work? (same relay as window)
  7. Aug 22, 2024 at 1:57 PM
    jonbert
    Yes, wiper works in the rear. window works with key. All locks work with the fob.
  8. Aug 22, 2024 at 1:58 PM
    jonbert
    Driving me nuts! It might be the harness.
    Noodles likes this.
  9. Aug 22, 2024 at 2:09 PM
    I wonder if these windows go through a body control module. Anybody know? I suspect it might, since I seem to recall having to reinitialize the windows after I had the battery disconnected a while.
    Speaking of which, it might be worth disconnecting the battery for half an hour or so…
  10. Aug 22, 2024 at 3:11 PM
    So you can open and close all the other door windows with the driver's door switch, with the exception of the driver front door window; the center console switch doesn't work to open the rear hatch window, but it opens with the key?
  11. Aug 22, 2024 at 4:42 PM
    jonbert
    No. Driver control totally dead. So is rear window switch on console. All other door windows and passenger lock work fine. As well as rear hatch window only with the key.
  12. Aug 22, 2024 at 4:43 PM
    jonbert
    thx for responses btw!
  13. Aug 28, 2024 at 5:22 PM
    jonbert
    taking to dealership tomorrow. ill let you know.
  14. Sep 1, 2024 at 10:58 AM
    Dave Tabs
    Dave Tabs New Member
    2010 4Runner SR5
    None
    Did you figure this out? I’ve got the exact issue with my drivers window only not working
  15. Sep 1, 2024 at 7:44 PM
    Dave Tabs
    2010 4Runner SR5
    None
    I’m really perplexed
    Curious what the dealer said… this photo shows how on the master switch, it’s only the drivers window that’s not getting power.IMG_5895.jpg
