Power steering
Discussion in '5th Gen 4Runners (2010-2024)' started by 2021venture, May 14, 2024.
  1. May 14, 2024 at 6:54 AM
    2021venture
    2021venture [OP] New Member
    Todd
    2021 Venture
    Are you guys doing anything extra to help out the power steering when running over sized tires? A power steering cooler is what I am thinking of. The extra strain on PS from off roading and big tires is my concern. Don't want to need a new rack or going to oversized Tundra rack. Turkey baster drain/fill with high quality synthetic ATF as often as I want has been the easy thing I have done so far. Thanks for any input.
  2. May 14, 2024 at 6:57 AM
    Jynarik
    Jynarik I like boobies
    Austin Texas
    2019 trd pro voodoo
  3. May 14, 2024 at 8:08 AM
    Nah I haven't seen anyone change anything around when adding larger tires. It wouldn't hurt anything if you did.
  4. May 14, 2024 at 8:20 AM
    2021venture
    Todd
    2021 Venture
    I don't see a lot of problems mentioned for PS. Think it's a safe bet PS not a problem until going to 35s and higher?
  5. May 14, 2024 at 8:22 AM
    It does survive the biggest rubber race everyone plays.
  6. May 14, 2024 at 9:10 AM
    Startrek
    Startrek New Member
    What has contaminating fluid in power steering? Metal dust from pump and hi-temp burn outs and water from condensation. Cool it off is good. Filtering it is good. Changing it frequently is the best. And cheap. Steering rack starts to leak when seals damaged by contaminants and/or cylinder scratched.
  7. May 14, 2024 at 11:06 AM
    1SilverRunner
    1SilverRunner My boy, blue
    Tejas
    22 TRD Off Road Premium
    Front Bumper: C4 Fabrication Low-Profile Bumper Warn Evo10-S Winch w/ Warn wireless adapter Extreme LED dual color light bar w/ Cali raised LED OEM style switch Bumper Cover Trimmed For Clearance Rear Bumper: 80% Off Road Rear Bash Bar Armor: RCI Skid plate package C4 Gas tank skid RCI Rear diff skid RCI Shock Skids RSG Angled/ Plated Sliders Total Chaos Cam Tab Gussets Total Chaos Spindle Gussets 41.22 Hitch Slider Suspension: Dobinsons IMS long travel kit (Front: IMS59-50574 w/ C59-352 Springs) (Rear: IMS59-50575 w/ C59-675v Springs) Apache Off Road UCAs Apache Off Road HD Rear Links (Upper and Lower) Apache Off Road Rear Sway Bar Links Dobinsons Track Bar Front Sway Bar Delete DuroBumps Rear Bump stops PerryParts Front Bump stops DRKDSS Track Bar Correction kit Dobinsons Diff Drop Wheels/ Tires: RRW 17x8.5 -12 RR6-H Wheels 285/75/17 Falken A/T4W 1.25" SpiderTrax Spacers BMC, Pinch Weld Folded. Custom High Clearance Fender Liners *Coming soon Performance: OTT Tuned Scan Gauge II for Temp Monitoring Yota Shop Diff Breather Storage Solutions: LFD Cross-Bars Aiden James Customs Gear Plate w/ Slide Out Tables *Backordered, coming soon Rado Designs Molle storage panels and top shelf Glove Box organizer Center Console organizer Interior: Diode Dynamics LED Interior lighting (Warm white ftw) Meso Customs Hatch lights Meso Customs Door Handle Covers Ram ball mount for Garmin In-Touch Mini II FitCamX Dash Camera Scosche phone mount Weathertech floor matts Misc: Nano Ceramic Tint (Including windshield and sunroof) Midland MXT575 and Ghost Antenna Cali Raised LED 27W Ditch Lights OVS Nomadic 6.5' Awning AVS Low Profile Vent Visor AVS Bugflector II Diode Dynamic puddle lights LasFit Reverse lights LED license plate lights Ark Splash Guards Ark Mud Flap Deletes AJT Push-To-Start Button +Midland handheld GMRS radios, Baofeng UV-5R Ham radio, recovery gear, water purification system, lifeboat food rations, trauma kit, fire extinguisher and fire starting kit stay on board.
    ^ I agree with power steering fluid flushes being the best preventative maintenance here.
    When it comes to cooling I think it comes down to application. In Texas it's common to see temps over 105-110f during the summer. Any hydraulic fluid can overheat and all hydraulic fluid degrades over time. My power steering pump hated me on 33's while wheeling in the summer. But most folks on this forum haven't experienced that. No offense to anyone.
    I think for short trips, fire/ forestry roads or even the occasional off road park it's not necessary (even with oversized tires.) But if you're running tight trails for 5-6 hours at a time in 105-115 degrees you will start hearing and feeling that power steering pump struggle. Depending on your mechanical empathy you may want to get ahead of that problem. Considering how easy it us to install an in-line heat sink I'd say do it if your application uncovers that weakness.
    Conversely, if you never hear power steering whine then don't worry about it. Your application doesn't necessitate it.
    Just my two cents.
    2021venture[OP] likes this.
