Power outlet not working?
Discussion in '4th Gen 4Runners (2003-2009)' started by Toyota2008, Sep 5, 2023.
  1. Sep 5, 2023 at 4:42 PM
    Toyota2008
    Toyota2008 [OP] New Member
    Plugged my Garmin into my power outlet in my 4 Runner and could not get it to turn on-thought maybe battery was dead needed charging, brought Garmin in house and plugged into wall and it turned on and charged right up-could power outlet in Toyota be bad?If it is what are my options?
  2. Sep 5, 2023 at 5:01 PM
    Here are some options:
    1. Plug another accessory in to see if it works, and/or check the fuse.
    2. Some plugs fit the outlet better than others. Sometimes the plugs resist being pushed all the way in, and the center contact doesn’t reach in far enough. So try plugging the Garmin onto the outlet again and see if it’s actually bottoming out in the outlet.
  3. Sep 5, 2023 at 5:12 PM
    backpacker
    backpacker New Member
    2023 TRD ORP
    Item 2 above has always been an issue for me in other vehicles. Some plugs work all the time, some work only if I keep pushing them back in, some hardly work at all.
  4. Sep 5, 2023 at 5:22 PM
    Did you turn on the outlet? There's a dash switch that turns it on.
    If you did turn it on, do lights on the switch light up?
    Ricphoto, Daddykool and 3JOH22A like this.
  5. Sep 5, 2023 at 5:33 PM
    3JOH22A Toyota Gigolo
    Is this the 12V outlet in the dash or the 110V AC outlet?
  6. Sep 5, 2023 at 6:02 PM
    Daddykool
    And you need to press that switch every time the truck is turned off and restarted.
  7. Sep 5, 2023 at 6:30 PM
    Tama1968
    Tama1968 New Member
    Florida
    T4R SR5 in Classic Silver
    are you talking about the power outlet (like the old cigarette lighter) up front? 1st check the fuse, but you could try one of the other outlets for the back seat too, they're all on the same fuse. Just did this yesterday on mine cos the front one wasn't working. turns out the center contact had a little carbon/crud on it. power off, carefully cleaned with a cotton swab and rubbing alcohol and fixed it right up.
    as for the house style outlet in the back....as others mentioned, gotta activate it with the switch up front
  8. Sep 9, 2023 at 4:19 AM
    AuSeeker
    AuSeeker Old As Dirt
    Skip
    South Carolina
    2004 Limited
    Also not mentioned is you need to have the ignition switch turned on to get power at the outlet.
  9. Nov 23, 2023 at 4:54 PM
    Nova2022
    Nova2022 New Member
    I'm having the same issue. I just bought my 2022 TRD O.F. yesterday. I went to plug in my dash camera in the cigarette lighter and no power. I even tried the one in the center console. Neither works. We checked the fuses in the fuse box and it's all good. Probably check in with the dealership next week. Annoying that neither works.
  10. Nov 23, 2023 at 4:58 PM
    Are you checking with the ignition on?
    Sorry if this seems obvious.
    SuedePflow, AuSeeker and Daddykool like this.
  11. Nov 23, 2023 at 4:59 PM
    Daddykool
    Did you try any other devices?
  12. Nov 23, 2023 at 7:45 PM
    Nova2022
    Nova2022 New Member
    It was running and tried my dash camera and my small seat heater. Both worked in my wrangler that morning.
  13. Nov 23, 2023 at 7:54 PM
    I'd take it back to the dealership and have them look at it. Hopefully it's something simple.
    Nova2022[QUOTED] likes this.
  14. Feb 24, 2024 at 1:19 PM
    CraigOutside
    CraigOutside New Member
    Billerica, MA
    2022 Toyota 4Runner TRD Sport
    I'm having a similar issue, last weekend both 12v cigarette lighter outlets (1 in front console, 1 in center console,) both have stopped providing power to the power supplies plugged into each. I found the fuse, and don't have a match for it, so that is another issue.
    My question is, do both of the 12v outlets have the same fuse? The USB power supplies, 1 in front console and 1 facing the 2nd row seats do work.
    Are there separate fuses for 12v outlets?
    Luna Runner likes this.
  15. May 31, 2024 at 2:14 PM
    Luna Runner
    Luna Runner New Member
    Charles
    Oregon
    2023 Lunar Rock ORP
    Stocky stock stock stock....for now. Just got it.
    My issue is the front 12v outlet in the center console will supply power just fine to my battery pack (solar generator / Bluetti) and charges at 100w. I checked that port and it is getting 13.85v. Then I went to the rear cargo area, and that port is also getting 13.85V when i check the plug that goes into the back of the battery pack. But when I plug it into the batter pack it starts to climb in input watts, getting up to around 75w on the display of the bluetti before falling back to 0w...it then just keeps repeating this cycle and never actually charging. Currently my work around is to use the inverter and the a/c adapter to charge it on trips which sucks if I don't push the dash button. I need the front port for charging other small things (or I would like to) and running a cable from the center console all the way to the rear isn't idea for sure.
    Anyone has any thoughts I'd love to hear them.
  16. Jun 7, 2024 at 3:07 PM
    4Runners 4Ever!
    4Runners 4Ever! New Member
    Colorful Colorado
    I had the same problem, in Park, engine on, switch wouldn't light. I'd used it before so something happened. Just pulled the dash cover behind the switch and found it had come out of its power harness. Reconnected and we're back up and running. Will keep an eye on it going forward.
  17. Jul 3, 2024 at 10:01 PM
    MatthewG
    MatthewG New Member
    Did you ever figure this out? Exact same issue with Jackery 3000 Pro.
