Power Antenna Disconnect
Discussion in '2nd Gen 4Runners (1990-1995)' started by Tannis133, Jan 16, 2021.
  1. Jan 16, 2021 at 11:20 AM
    Tannis133
    Tannis133 [OP] New Member
    1995 4Runner
    Easiest solution to disconnecting my power antenna? Thanks
  2. Jan 17, 2021 at 5:54 PM
    Justthemechanic
    Justthemechanic New Member
    Nevada desert
    94 4Runner SR5, 5 speed, 3.0
    OME 2” lift, BudBuilt armor, RRO sliders, Spartan rear locker
    Remove the plastic inner fender liner and disconnect the wire at the motor.
    mousemeat likes this.
  3. Jan 18, 2021 at 4:45 AM
    Tannis133
    1995 4Runner
  4. Jan 18, 2021 at 10:21 AM
    trlhiker
    trlhiker Lazy Bum
    1992 4Runner SR5 V6 4X4
    I am surprised it still works. My quit over 5 years ago.
  5. Feb 1, 2021 at 2:06 PM
    watermelonman122
    watermelonman122 New Member
    Utah
    1994 4Runner SR5 3.4 V6 4wd 5spd
    I swapped out the power antenna for a regular one. Looks way better and cheap to replace.
  6. Apr 26, 2021 at 7:22 AM
    mostlystock93
    mostlystock93 New Member
    93 4runner 3vze 4WD, Ellsworth Enlightenment 29er
    slight lift, aftermarket headers, cold air intake
    I bought a solid antenna from crutchfield-it came with plenty of cable to reach the stereo, it can be easily removed if you’re going through a car wash and I used the stock body plate to have the new one fit like the stock antenna.
  7. May 22, 2021 at 6:25 PM
    Pyroslinger
    Pyroslinger 1995 Hi-Lux Surf 3.0 3VZE Factory 250,000
    Pyroslinger
    Montana
    1995 Hi-Lux Surf SR-5 3.0 3VZE / Bought at 29,000 - Present 250,000/ Rusted Body, Excellent Otherwise
    Factory/ 2" Ol Man Emu Rear Springs/ Skyjacker Shocks/ Cat- Back Exaust/ K&N Air Filter/ Denso Iridium Plugs/Neoprene Vacume Lines/Sony CD Head Unit+Focal Factory Fit Speakers
    I like the stock antenna. Got one off of Amazon, cheap. Not real fun to install, not difficult..
    Just a pain in the ass and covered in that once white now black grease. It works great after feeding in the new plastic gear strip..teeth facing to the rear.
  8. Aug 5, 2021 at 9:39 AM
    mousemeat
    mousemeat New Member
    Memphis, TN.
    1997 4 runner limited
    mine still works...I need to grease it..from time to time...as it gets noisy going down..
