Post lift settling?
Discussion in '5th Gen 4Runners (2010-2024)' started by Patwashere, Jun 25, 2023.
  1. Jun 25, 2023 at 4:57 PM
    Patwashere
    Patwashere [OP] New Member
    ID - Idaho
    quick question on settling.
    I just installed Ironman stage one (2.5 front and 2.0 rear) on my '23 ORP with KDSS yesterday. I chose the coil over to be pre-built. After installation my measurements on the front are added + 3.5 inches. That's way more than the 2.5 expected and it's on KDSS which I understand is bad to go over 3 inches. I did drive it a bit today over some rough road and a bit off-road with a few bumps. I am waiting to do an alignment on Monday.
    Should I expect the settling to reduce the lift height enough to get to the 2.5 lift range? Or do I need to get the adjustment tool?
    The adjustment tool from Ironman shows out of stock ATM. Does anyone in the inland northwest have one that i could borrow?
    Thanks.
    --pat
  2. Jun 25, 2023 at 6:05 PM
    JETSPD1477
    JETSPD1477 New
    Typical 4Runner
    The extra inch can be attributed to both misalignment and settling. there's even a little bit of break in for the shocks. once you get it aligned then drive it around for a bit to get a good measurement and see if you really need to get in there with a spanner wrench.
    Patwashere[OP] likes this.
  3. Jun 25, 2023 at 6:51 PM
    Could be that your new springs have a higher load rating than you needed.
  4. Jun 25, 2023 at 7:40 PM
    HuskyMike
    HuskyMike New Member
    To piggyback on this comment... Did you choose the medium or heavy load spring option?
  5. Jun 25, 2023 at 7:44 PM
    Patwashere
    ID - Idaho
    the medium ones. I've added rock sliders which add to the stock weight.
  6. Jun 26, 2023 at 9:48 PM
    Patwashere
    ID - Idaho
    Just an update. Got the alignment done today and went for a 20 mile dirt road test. Had lots of potholes and ruts etc..
    The front dropped a bit and now is only 3 inches. so the alignment and test drive took .5 inches off the front. Rears stayed the same lift.
