Portable air compressors
Discussion in 'General 4Runner Talk' started by bassist, Sep 3, 2023.
  1. Sep 3, 2023 at 6:31 PM
    bassist
    bassist [OP] New Member
    2023 TRD Offroad Premium
    So my 35 year old ARB air compressor has given up the ghost. While I'm going to see if there's a way to coax it back into life, I may need to accept the fact that it's time to get something new.
    Just wondering what everyone is using. Thor's Lightning looks intriguing, and there's always just paying extra to get an ARB unit, or...
  2. Sep 3, 2023 at 6:49 PM
    Jynarik
    Jynarik I like boobies
    Austin Texas
    2019 trd pro voodoo
    What’s the use?
    I have a dewalt portable compressor that works great, but it’s not in my 4runner. I have onboard ARB twin compressor for getting quick air ups done.
  3. Sep 3, 2023 at 6:55 PM
    backpacker
    backpacker New Member
    2023 TRD ORP
    I chose the Viair 400P. It airs up pretty fast, especially compared to the small compressor I carry in my Outback.
    icyhotahs and Captain Spalding like this.
  4. Sep 3, 2023 at 7:21 PM
    Thacrow likes this.
  5. Sep 3, 2023 at 8:03 PM
    bassist
    Looking for airing up. Not sure I want to mount it up at this point in time.
  6. Sep 3, 2023 at 9:24 PM
    I use a Viair 300P I customized. It's been fine for my needs. It takes about 2 minutes per tire to get my 295's from 12 up to 35 PSI.
    Otherwise, a few guys I know use the 88P without issues.
  7. Sep 3, 2023 at 9:51 PM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
  8. Sep 3, 2023 at 9:55 PM
    Hey @bassist, I run a simple portable 120v Craftsman truck tire pump from Lowe's. Bungie corded on top of the rear passenger trunk wheel. Typically plug it into the 400w outlet
    TrailSpecial22 and bassist[OP] like this.
  9. Sep 4, 2023 at 12:07 AM
    Thacrow
    Thacrow New Member
    2021 ORP
    Speed holes
  10. Sep 4, 2023 at 4:53 AM
    bassist
    Looks like it was totally meant for this exact application!
    pastoreater likes this.
  11. Sep 4, 2023 at 1:06 PM
    bassist
    Okay, I discovered something.
    My old one still works - I had not connected the air hose before starting it.
    *facepalm*
    raimieb likes this.
  12. Sep 10, 2023 at 5:54 AM
    TrailSpecial22 New Member
    PA
    I know it over buts its all i got. But I am now looking into. That Vlair unit for sure
    Rupp1 and Thatbassguy like this.
  13. Sep 17, 2023 at 11:04 AM
    Bluesky 07
    Bluesky 07 Not a New Member
    Russell
    Northern Georgia
    Silver ‘07 Sport 4WD @ 257K miles
    “Deep” Satoshi grille | X-REAS delete / TRD Offroad front springs & Bilstein 4600 shocks + FJC rear springs | Weathertech front & rear mats | Tinted front windows | Floor Armor cargo mat | TPMS bypass | LED interior, tag, & reverse lights | BlueSea Systems console USB power ports | Gentex 453 autodim mirror w/Homelink & compass | Kenwood DDX373BT HU + Audiovox backup camera | Fumoto F-103S | Bazooka tube subwoofer | Kenwood speakers & KAC-M1804 amp | Philips H9/9011 headlight bulbs | Rexing V1 Gen3 dash cam | Map light mod | Breather mod | Off-road Nav Setup | Power Stop Z36 brakes | OBD Fusion diagnostics
    Ran across an excellent accessory for my Viair 88P or any other compressor where the hose screws on to the tire valve. This self-locking, quick release extension, available for $8 on Amazon, is way faster to attach/detach and also features a deflation button.
    Also, my 88P didn't come with a case and many reviews that mentioned the Viair case complained about how tight it was to get the compressor, power cord, and air hose back in once it was out. I noticed this Ozark Trail 360 tackle bag for ~$21 at Walmart and it's perfect. The 88P and my Jaco deflator fit in the main section, a small toolkit in the front pocket, and there's plenty of room left. Bonus: inside it are 4 plastic compartmentalized storage boxes meant for lures and such but ideal for small parts, screws, washers, etc.
  14. Sep 17, 2023 at 11:09 AM
    coryanderson
    coryanderson New Member
    Cory
    2018 SR5 4x4 - black and tan
  15. Sep 17, 2023 at 12:46 PM
    Nice dude! Happy I saw this, I'm totally gunna buy a quick release extendo. Like today. Thanks, no idea why I didn't do this earlier having to twist my damn 4R pump hose so much
  16. Sep 17, 2023 at 1:25 PM
    Prime, here tomorrow, lol. Inflator AND deflator :D
  17. Sep 17, 2023 at 1:38 PM
    The quick release mechanism on the first one posted is nicer, IMO.
    Edit: just in case anyone is considering both.
    Thacrow likes this.
  18. Oct 6, 2023 at 11:54 AM
    weeeniewagon
    weeeniewagon New Member
