Popping noise when going around curves up/down hills.
Discussion in '4th Gen 4Runners (2003-2009)' started by Pos4runner, Jan 10, 2021.
What can be the issue?
  1. Transfer case
    0 vote(s)
    0.0%
  2. Center differential
    0 vote(s)
    0.0%
  1. Jan 10, 2021 at 8:58 PM
    Pos4runner
    Pos4runner [OP] New Member
    2003 4Runner 4.7 sport
    Hey there, so I’ve been in a bit of a haste the past two months with my 4Runner, it’s a 2003 4.7 4wd sport edition, so I started to get this popping noise coming from the front/middle of the vehicle. Now keep in mind before this happened my transfer case would never let me go into 4low so I never touched it. Anyways, the popping noise continued to get worse and worse so I figured it’s An axle so I replaced the axles, meanwhile it still done it. So I took out the center differential and turned on differential lock and it would go just fine without a popping noise so I figure it was the front driveshaft so I replaced it with a brand new one. Same issue, soon as this started happening my transfer case started to work and I could drive in 4low, before the transfer case would never lock into 4low. Ever.
    im running in circles here lost and I have no idea what to do, I have a family of two and I’m just so lost cause it’s the only vehicle that we have.
    what is your thoughts?
  2. Jan 22, 2021 at 5:43 AM
    Bonitobob
    Bonitobob New Member
    06 V8 Sport
    They say the driveshaft “propeller “ should be greased real good (6 fittings down there) and there are bolts to to torqued every 30k mikes so they say. They are known to make a popping sound if not greased.
  3. Jan 25, 2021 at 4:26 AM
    captsolo
    captsolo New Member
    Tom
    nassau bahamas
    2005 SR5
    Moral of story: "stay away from 4wheel drive - most people never even use it." - according to the experts
  4. Jan 25, 2021 at 9:28 AM
    4scooter19
    4scooter19 New Member
    Oregon
    98 and 86 4Runners
    Maybe in the Bahamas.....
    y=mx+b likes this.
