Pls help find Squeak in front left (pic)
Discussion in '5th Gen 4Runners (2010-2024)' started by Steve Berman, Sep 28, 2024.
  1. Sep 28, 2024 at 4:20 PM
    Steve Berman
    Steve Berman [OP] New Member
    Hello, I have had a squeaky noise from the front drivers side when I go over bumps or holes, only noticed during left turns.
    I see a small area where it appears the 'sway bar?' may have moved a little? The sound is reminescent of an up and down squeak from a roomates frame bed..
    Any known things to look for?
    Thank you
  2. Sep 28, 2024 at 5:14 PM
    Nearly 92.3 percent of suspension squeak noise complaints are actually coming from the hood latch. I’m not joking. Well, the statistic is made up, but my point stands.
    Put a little (just a little) thin coat of your favorite grease on the contact points of the hood latch and mechanism. If the sound disappears, then you just saved a ton of money, time, and heartache.
  3. Sep 28, 2024 at 5:27 PM
    Lc200
    Lc200 New Member
    Pre Facelift SR5P
    If not the hood latch, the hood rubber stops. A dab of silicone grease.
    Steve Berman[OP] likes this.
  4. Sep 28, 2024 at 5:29 PM
    Steve Berman
    Gonna try that now, thank you!
  5. Sep 28, 2024 at 7:09 PM
    Ais4awesome4
    Ais4awesome4 New Member
    CO
    2016 sr5 4x4 100k mi
    265/70/17 Falken at3w
    If it the hood latch/hood stops don’t turn out to be the issue, I’d turn the wheel left and bounce up and down on a rock slider or a side step and see if you can hear it. If you can, get someone else to bounce on it and try the rubber hose/screwdriver trick on some suspension components.
    Also, if you’re concerned about that mark on the sway bar being the cause of spray some silicone line on it and see if that quiets it up
  6. Sep 28, 2024 at 10:33 PM
    Rick G.
    The Texas Hill Country
    2022 SR5 Premium 4WD
    I was getting annoying squeak noises in the front of my 2022 SR5 Premium 4WD. I traced it to those two hood rubber bump stops at the left front and right front corners of the hood. I spritzed those rubber bump stops with some WD40. Squeek problem solved!
    If the problem returns, I’ll hit the two rubber stops with more WD40, or brush some light grease on them.
    Slopemaster and raimieb like this.
  7. Sep 29, 2024 at 3:39 AM
    Guppy1301
    Guppy1301 New Member
    Silver 2019 TRD ORP
    Check your engine splash shields, too.
  8. Sep 29, 2024 at 8:38 AM
    VeryProudOfYa686
    VeryProudOfYa686 New Member
    CHRIS
    2023 Lunar Rock ORP
    This is what was causing my noise. Whne I turned my wheeels out, the wind would catch ther splash shield and the rubber would catch on the frame making a squeakign noise. Looks like yours has a significant amount of warping too.
